xr6turnip Fordmods Parts Gopher
Posts: 64 Joined: 07 Dec 2007 Location: sydney NSW, Australia
Posted: Tue Jun 10, 2008 9:47 pm Post subject: Windsor V8's, are they lazy? whats to blame? |
My EL Fairmont windsor V8 has extractors, 2.5 inch exhaust system, K&N Panel filter, AU220 snorkel, 3.45 diff gears, LSD, 18 inch wheels and ive bumped the timing up a few degrees... only 87,000km and its an auto.. In fantastic condition..
My Windsor V8 is probably typical of its characteristics, very punchy off the line, quick to 60km/h. The car feels fantastic from 1000-4000rpm but doesnt really build much more grunt after 4000rpm.. You will be flat on the throttle and it doesnt seem to feel like its working that hard... It revs out reasonable quickly and changes up about 5500rpm but doesnt feel like it makes great power up top in the rev range..flat on the throttle... 0-100km/h in about mid 7s so typical performance from this type of car...
Is that just how they are? whats to blame... |
needfordspeed Fordmods - Getting Side Ways
Age:20 Posts: 439 Joined: 16 Feb 2005 Location: Melbourne VIC, Australia
Posted: Tue Jun 10, 2008 9:54 pm Post subject: |
| The heads and whole intake system are to blame |
Vic Cruise Moderator
Posts: 5569 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Tue Jun 10, 2008 10:10 pm Post subject: |
| Yep they are quite asthmatic in stock form. The E7 heads and HO intake on the 165kw engines are restrictive and they suck air as though through a straw. Unfortunate, however due to the smorgasbord of aftermarket parts for the Windsor, you can throw some money at them and they come alive very very easily. |
Age:21 Posts: 1658 Joined: 13 Aug 2005 Location: Perth WA, Australia
Posted: Tue Jun 10, 2008 10:13 pm Post subject: |
| needfordspeed wrote: | | The heads and whole intake system are to blame |
Yep in brief thats it.
Heads are s**t, HO inlet manifold is s**t, std T/B is s**t, std MAF is s**t, std exhaust manifolds are s**t. Std cam is a nice torquey cam but runs out of grunt up high. The yanks have got good results from the std cam mated with 1.7 rockers. Would be interesting to see how the std cam would go with some decent heads and intake and 1.7 rockers. Are you willing to try??
Are you looking to spend any money on getting it to move abit better or were you just wondering why it was so slow? |
Age:24 Posts: 1718 Joined: 25 May 2006 Location: Perth WA, Australia
Posted: Tue Jun 10, 2008 11:12 pm Post subject: |
| XH5LWEPN wrote: | | needfordspeed wrote: | | The heads and whole intake system are to blame |
Agreed. Could be worse though, you could have an auto.... |
Posted: Tue Jun 10, 2008 11:17 pm Post subject: |
| schnoods wrote: |
He does  |
XR9UTE EFI Guru
Age:43 Posts: 1459 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Tue Jun 10, 2008 11:33 pm Post subject: |
Yes and the power drop off after 4000rpm is an example of the lack of outright flow.
Otherwise the 5.0 in stock form has excellent torque.
In fact the stock HO upper is a good piece...the lower lets it down.
Port the HO upper for a 65mm t-body and a ported HO lower(or buy a Holley systemax 1 lower if you could still get one?)with AFR 165 or other small port aftermarket heads and a stock cam with 1.7's would be a good way to wake it up WITHOUT losing all the bottom end. |
Timmeh Moderator
Posts: 6464 Joined: 06 Nov 2004 Location: Perth WA, Australia
Posted: Wed Jun 11, 2008 10:13 am Post subject: |
| XR9UTE wrote: |
Port the HO upper for a 65mm t-body and a ported HO lowerwith AFR 165 or other small port aftermarket heads and a stock cam with 1.7's would be a good way to wake it up WITHOUT losing all the bottom end. |
WOW thats news to me. Had no idea the HO upper was any good.
castlegreyskull Cruise Moderator
Age:25 Posts: 3933 Joined: 14 Dec 2005 Location: maryland, newcastle NSW, Australia
View User Gallery (34)
Posted: Wed Jun 11, 2008 11:38 am Post subject: |
| Yeah i have heard about the upper HO being alright, but by the time you spend the money porting out, you may aswell just go and buy a explorer/cobra manifold or even a aftermarket one. |
XR9UTE EFI Guru
Posted: Wed Jun 11, 2008 3:10 pm Post subject: |
| castlegreyskull wrote: | | Yeah i have heard about the upper HO being alright, but by the time you spend the money porting out, you may aswell just go and buy a explorer/cobra manifold or even a aftermarket one. |
True, but that assumes you will be paying someone to do it. It's something you can do yourself and there's plenty of info about how to do it. I'd probably buy a Cobra because I have next to no time anymore. |
Posted: Thu Jun 12, 2008 2:02 pm Post subject: |
I guess the mods tidied it up and deleted the quad post and any posts referring to the quad post, . |
Age:29 Posts: 441 Joined: 14 Jan 2007 Location: Perth SoR WA, Australia
Posted: Thu Jun 12, 2008 3:33 pm Post subject: |
Yes its called housekeeping...  |
Posted: Thu Jun 12, 2008 10:38 pm Post subject: |
id do the heads and intake if it didnt kill my fuel economy... mine is a daily driver... |
Posted: Thu Jun 12, 2008 10:52 pm Post subject: |
The economy wont suffer too much, its a matter of not keeping the right foot down with the new found enjoyment.  |
prydey Fordmods - Getting Side Ways
Age:31 Posts: 1669 Joined: 31 Jan 2005 Location: Adelaide SA, Australia
Posted: Fri Jun 13, 2008 1:09 am Post subject: |
| xr6turnip wrote: | | XH5LWEPN wrote: | | needfordspeed wrote: | | The heads and whole intake system are to blame |
when i did the heads and intake on mine, even though the power went up the economy stayed the same. so in effect the motor is more efficient.
i get about 420ish give or take off 65L give or take and thats with auto and 3.9diff and cam. i'm never in traffic though.
if you want your old ported ho manifold back its sitting under my bench but postage will be a bit more difficult than the springs. be too big for aust. post i reckon. |
Age:36 Posts: 2337 Joined: 25 Nov 2004 Location: Sydney Australia NSW, Australia
Posted: Fri Jun 13, 2008 1:44 am Post subject: |
Nope, can be posted. I recieved a 351 lower through Aust Post from SA to Sydney
Brett |
Steady ED Fordmods Addict
Age:22 Posts: 6870 Joined: 01 Jun 2005 Location: Melbourne VIC, Australia
Posted: Fri Jun 13, 2008 11:37 am Post subject: |
| yeah I got an upper and lower intake posted from adelaide, no dramas through aust post. |
Age:30 Posts: 991 Joined: 26 Nov 2006 Location: Perth WA, Australia
Posted: Fri Jun 13, 2008 12:34 pm Post subject: |
I reckon my fuel economy has gotten better with everything I have in at the moment. When driving around normally, making gear changes at around 2500, I'm seeing around 11l/100km or better. My current tank I've seen 310km and it's just hit the half way mark. On the dyno it says I'm running rich too, so when I get the Motec in and it's tuned correctly, I'd hope to see better economy yet! |
[46 queries :: 0.06951 seconds ]
