Wireless networking
fairmont1
PostPosted: Tue Apr 22, 2008 5:45 pm    Post subject: Wireless networking Reply with quote
hi, my aunt wants to keep holes to a minimum and im just wondering if its possible to put 2 antennas up on the shed on seperate poles one facing the wireless modem router and the other one directed to wherever i go so i can transmit the wireless signal as far as i can.
would it be as simple as connecting one end of the cable to the antenna facing the house and the other end to the antenna facing whereever i go and it will relay the signal without putting holes in the walls in the house or wont it work.
i want to transmit the wireless signal for about 20 kms thursdays and fridays and the rest of the wk about 10-15 kms.
how high would the pole have to be if i had a high gain antenna.
RedRoo
PostPosted: Tue Apr 22, 2008 7:16 pm    Post subject: Reply with quote
How much money have you got?
It would be cheaper buying the portable wireless setup.
fairmont1
PostPosted: Tue Apr 22, 2008 7:50 pm    Post subject: Reply with quote
whats the portable wirelss setup how much is it and will that last for atleast 20 kms
Nicko
PostPosted: Tue Apr 22, 2008 7:59 pm    Post subject: Reply with quote
moved to geeky forum
RedRoo
PostPosted: Tue Apr 22, 2008 8:32 pm    Post subject: Reply with quote
Have a look at the bigpond ad with the bongo bus in it.
To do what you want to do your going to need to run cable in plastic conduct from the wireless modem inside to the antenna outside,
you are going to need a sturdy antenna base, a good quality antenna to suit, a booster to boost the signal to a level to enable a strong connection,
more than likely permits and licences to build and operate the edquipment and heaps of money to buy all the stuff you are going to need.
savage78
View User Gallery (16)
PostPosted: Wed Apr 23, 2008 8:32 pm    Post subject: Reply with quote
can cost from $1 to $1000s have a look on ebay wanted to run wireless to shed but went cable for like $20.00 for 15 meters of ethernet cable and wireless cuts in and out all the time better to go cable over wireless
RedRoo
PostPosted: Wed Apr 23, 2008 9:05 pm    Post subject: Reply with quote
mate he wants to use it 20 klm's away or 20,000 meters not 20mts.
basstrom_dave
PostPosted: Wed Apr 23, 2008 11:59 pm    Post subject: Reply with quote
most wireless network antennas are omni-directional thou it is possible to get directional ones which can transmit over long distances, but expensive and not sure on the quality like dropouts and transmission loss.
as has been said look at the wireless boradband cards some are reasonable in price.
DoddEA
PostPosted: Thu Apr 24, 2008 3:16 pm    Post subject: Reply with quote
We have bigpond wireless.. think its 55 a month and ya get 200mb download. Now thats dad's s**t plan, but if ya ring bigpond they will have much better plans with my download.
Trying to run a wireless network more than 20km's the road... not a very cost effective idea. Either a) do as above and get wireless internet. or b) Get cable wherever your 20km distance is. It will be cheaper.
robertf123
PostPosted: Thu Apr 24, 2008 10:17 pm    Post subject: Reply with quote
im pretty sure that 20km quite impossible on any residential wireless set up, something like telstras wireless broadband would be the go
zxhoon
PostPosted: Tue Apr 29, 2008 2:10 pm    Post subject: Reply with quote
not to mention even if you had a decent transmitter at your aunts place, you would need the same gear at your end to transmit data back...
dont bother with telstra for wireless unless you have bad coverage from other mobile carriers in your area, telstra are good for coverage, bad for pricing... check out some other wireless ISPs...
for instance:
http://bc.whirlpool.net.au/bc/isp-996-3/virgin-broadband-mobile-broadband.htm
http://bc.whirlpool.net.au/bc/isp-3-4/optusnet-wireless.htm
http://bc.whirlpool.net.au/bc/isp-1-3/telstra-bigpond-nextg-wireless.htm
[38 queries :: 0.04657 seconds ]
