with dual fuel can you change 1 to the other while driving
lethal EA
PostPosted: Sun Jun 03, 2007 5:42 pm    Post subject: with dual fuel can you change 1 to the other while driving Reply with quote
quick question, with dual fuel can you change 1 to the other while driving or not?
and what should you start with in the morning
pugsley
PostPosted: Sun Jun 03, 2007 5:51 pm    Post subject: Reply with quote
i change mine from gas to petrol while driving and don't have any problems. i was told not to change over under load because it will backfire. mine starts on petrol each time even if set on gas. i also run on petrol for around 10kms each time i run out of gas. this is also supposed to be the go to keep petrol system happy. i love my lpg saves me plenty, i had a crewman ss before (no lpg) and changed to ef fairy. Saves me plenty on fuel and is more useful (has a back seat that you can use) and soooo much nicer to drive icon_wink.gif
richard williams
PostPosted: Sun Jun 03, 2007 6:05 pm    Post subject: Reply with quote
I do it all the time.
No probs.. The old systems with carbies needed to be run out between changeovers so the float bowl in the carbie was emptied
twr7cx
PostPosted: Sun Jun 03, 2007 6:33 pm    Post subject: Reply with quote
mine isn't happy unless your reving it when changing (be it driving or idle).
fnp
PostPosted: Sun Jun 03, 2007 6:59 pm    Post subject: Reply with quote
A lot of systems start on petrol and switch over to gas on their own.
cheersdude
PostPosted: Sun Jun 03, 2007 8:21 pm    Post subject: Reply with quote
Yeah mines the same, switch's to petrol fine at idle, but have to rev it a bit when ya switch to lpg @ idle..
bArNsY
PostPosted: Sun Jun 03, 2007 10:57 pm    Post subject: Reply with quote
I am pretty sure mine has a petrol start and then runs on gas, i always run it on petrol at least once every 45 days and keep 1/4 tank of fuel in the car all the time
twr7cx
PostPosted: Sun Jun 03, 2007 11:09 pm    Post subject: Reply with quote
If you have a steel fuel tank (which AFAIK the sedans do not) always keep a full tank of petrol in there otherwise the tank will rust inside.
hans hartman
PostPosted: Mon Jun 04, 2007 1:11 am    Post subject: Re: with dual fuel can you change 1 to the other while drivi Reply with quote
start them up on lpg,change to either at 80-100ks,i have 4 duel cars------even -5 deg c mornings
basstrom_dave
PostPosted: Mon Jun 04, 2007 2:21 am    Post subject: Reply with quote
Hardly any problems either, have an EB I starts on both though needs to crank a few more times on gas to start. Also have to increase the RPM a lil bit when changing otherwise all good, save lots of $$$!!
lethal EA
PostPosted: Mon Jun 04, 2007 9:04 pm    Post subject: Re: with dual fuel can you change 1 to the other while drivi Reply with quote
so you cant change from petrol at start up to lpg in the first 1 minute at idle???
AU99
PostPosted: Thu Jun 07, 2007 10:02 pm    Post subject: Reply with quote
most lpg cars start on petrol run for about 2-6 seconds then change to lpg (aids starting) others change when you accelerate. I hear that vapour injection the engine has to warm up to a specific temp before it switches over.
there are many systems out there and they are all different.
Factory tickford systems start on petrol and change over virtually straight away.
MICKYYYY
PostPosted: Sat Jun 09, 2007 6:05 pm    Post subject: lpg gas Reply with quote
Apparently ur sopposed 2 start on petrol to help lubrication for the head and keep fuel system up 2 scratch. I think the injection gas system automatically do that then they automatically change to gas???
hans hartman
PostPosted: Sat Jun 09, 2007 6:17 pm    Post subject: Re: with dual fuel can you change 1 to the other while drivi Reply with quote
2 cars start petrol then switch to gas,other start on gas straight up, in the mornings----2 cranks
[41 queries :: 0.04328 seconds ]
