Wolf 3D V4 problem
Cy4NiD3
PostPosted: Tue May 06, 2008 10:58 am    Post subject: Wolf 3D V4 problem Reply with quote
I have just go my wolf installed making 40 more rwhp with a turbo to say the least i am unhappy there seems to be a problem with timing issues for some reason idle is 0 degree's then once it hits full boost it is retarding the timing 16 degree's so loosing a hell of alot power does anyone have any idea's what would be causing it to retard itself???
madeaspack
PostPosted: Thu May 15, 2008 3:55 pm    Post subject: Reply with quote
did you set it all up right? like move the hall effect sensor ect to set the timing where the wolf wants it to be?
Cy4NiD3
PostPosted: Thu May 15, 2008 11:30 pm    Post subject: Reply with quote
Dont have a Hall effect sensor using Cam angle sensor gonna take it to soemone who might have an i dea to get it working after i cahnge the engine around stupid piston rings icon_sad.gif
TURBO_GHIA
PostPosted: Fri May 16, 2008 4:32 pm    Post subject: Reply with quote
wolf's are a pain to get working ,just get the ef converter plug thing from wolf
Cy4NiD3
PostPosted: Fri May 16, 2008 7:49 pm    Post subject: Reply with quote
The 2 channel reluctor?.... Yeah i have that seems to me making no difference so am thinking possibly sensor might be F**k?....
I am also wondering if it's a possible timing chain issue... at 4K when it's just starting to boost you can see the harmonic balancer move around about 7degree's or sumthing but with a timing light you can see it moves massivly around is this normal?
I have also blown a Piston on no 5 so possibly causing the knock sensor to mess it around bit shouldnt affect it....
madeaspack
PostPosted: Wed May 21, 2008 10:09 am    Post subject: Reply with quote
have you changed the tone wheel thing on the crank?
Cy4NiD3
PostPosted: Thu May 22, 2008 12:24 pm    Post subject: Reply with quote
Tone Wheel?... you mean the harmonic balancer... No as far as i know it is still a standard EF 36+1 Tooth Wheel... Wolf software can pickup the 36+1 now supposedly... but it's unsual because it's smooth at idle n stuff so cant be anything to do with toothed wheel i dont think..... jsut doesnt pick up thats it's changing it's timing at higher revs :S
[34 queries :: 0.02931 seconds ]
