XD ESP??.....
Milesy
PostPosted: Tue Jan 29, 2008 12:52 pm    Post subject: XD ESP??..... Reply with quote
G'day Guys,
I'm new to Ford Mods but am loving it already.
I have an XD ESP With a V8 in it. I wasn't sure if it was a real ESP so i got it looked at by a professional, he said it was indeed an esp but the 351 and gearbox were not original...
any ideas on value????
howsie
PostPosted: Tue Jan 29, 2008 3:11 pm    Post subject: Reply with quote
i know a bloke with an XD ESP, difference is its all original and it is valued at $15,000.
(2 months ago)
4dlvr
PostPosted: Tue Jan 29, 2008 4:55 pm    Post subject: Reply with quote
dont bother selling it, ive seen a few go for about 5k.
ild rather keep it if i were you.
dam i love those things 351, 190+kw. close to 500nm and their light as f**k
Milesy
PostPosted: Tue Jan 29, 2008 8:17 pm    Post subject: Reply with quote
Thanks fellas,
I'm now thinking about just restoring it, would i be better off looking for a 6cyl like it came out of the factory or sticking with the 351?????
BigCav
PostPosted: Tue Jan 29, 2008 8:42 pm    Post subject: Reply with quote
stick with the v8, price wont change much if not go down if its got a 6 cyl, they are worth a little bit of money but the only ones worth a fortune are the original matching numbers 351's
BigCav
PostPosted: Tue Jan 29, 2008 8:43 pm    Post subject: Reply with quote
dunno where u got those facts from but there off, they only make 149fwkw and 415fwnm
Priestly007
View User Gallery (16)
PostPosted: Tue Jan 29, 2008 8:44 pm    Post subject: Reply with quote
unless you can track down the matching numbers Id stick with the 351..... v8 goodness
4dlvr
PostPosted: Wed Jan 30, 2008 12:19 pm    Post subject: Reply with quote
i doubt that BigCav. i cant remember exact figures but ive seen them a few times no no that my figures are very close. ive been in a few and i can assure you they got more then 149kw
BigCav
PostPosted: Wed Jan 30, 2008 2:22 pm    Post subject: Reply with quote
unfortunatly mate the ones i posted are the power figures, they never touched the motors in the esp range's and they were only as powerful as the basic 351's and 302.
the 302 makess 140kw and the 351 makes 149 kw.
iv driven a number of stock xd/xe 351's and now own a modified one and my worked one is probably only up to 190fwkw
full spec sheets can be found at falcon facts, the esp forums, xfalcon
however ill list them for u anyway, this is for the xe esp however mos tif it is the same for the xd, the xd should of had the bathurst globe wheels instead fo the snowflakes
Engine
5.8-litre, OHV, V8, 4-barrel carburettor, 8.9:1 compression ratio, 149kW@4300rpm, 415Nm@3000rpm.(DIN)
Transmission
4- speed manual, all synchro.
Ratios: 1st 2.46:1- 2nd 1.78:1 - 3rd 1.27:1 - 4th 1.00:1
Reverse 2.47:1
FMX 3-speed automatic, T-Bar shift.
Ratios 1st 2.40:1 - 2nd 1.47:1 - 3rd 1.00:1
Reverse 2.00:1
Rear axle: 2.92:1 (manual) 2.77:1 (auto) limited slip differential.
Suspension
Front: Independent, upper and lower wishbones, heavy duty coil spring over strut-type Bilstein dampers and anti-roll bar.
Rear: Live axle, upper and lower trailing arms, heavy duty coil springs, telescopic Bilstein shock absorbers and 24 mm anti-roll bar.
Brakes
Front 286mm ventilated discs, rear 286mm discs, servo assisted.
Wheels
7JJ X 15" gold snowflake pattern alloy wheels, ER60H15 Uniroyal Wildcat steel-belted radials
Performance
0-100 km/h - 8.8 seconds; Standing 400m - 16.1 seconds
BigCav
PostPosted: Wed Jan 30, 2008 2:23 pm    Post subject: Reply with quote
oh also the xd esp was still leaf spring not coil, and as such was factory fitted with tramp rods
TerroristGHIA
PostPosted: Wed Jan 30, 2008 2:59 pm    Post subject: Reply with quote
The gold snow flakes were on the XE, the XD had Globes, same as Cobra and HO III. Also interoir instruments should be red, not green like the GL
Brett
Milesy
PostPosted: Wed Jan 30, 2008 6:03 pm    Post subject: Reply with quote
Thanks Guys!!!!
this info is priceless!!!!
i love this site!
i think i'll stick with the V8, the worst thing is i already researched the rims needed and bathurst globes are about $1500 a set from what i've read, bloody expensive set of rims but i think they'll be worthy...
thanks guys!!!!!
cjh
PostPosted: Thu Jan 31, 2008 7:55 pm    Post subject: Reply with quote
The XE ESP's in 351 spec had engine oil coolers and used the shorter oil filter, Ryco # 89A.
edv8wagon
PostPosted: Fri Feb 15, 2008 7:10 am    Post subject: Reply with quote
I thought the ESP was only available in the XE?
wild_ef
PostPosted: Fri Feb 15, 2008 12:25 pm    Post subject: Reply with quote
there were a few xd esp's made aswell.
milesy post up a few pictures of your car n give everyone a look icon_biggrin.gif
Munch
PostPosted: Fri Feb 15, 2008 12:40 pm    Post subject: Reply with quote
Yeah, I've seen original XD ESP's in white and red... I thought originally that it was only white... but I was wrong.......
BigCav
PostPosted: Fri Feb 15, 2008 6:49 pm    Post subject: Reply with quote
xd esp were alot more diverse then xe's
id almost say that the xd was more of an option u added to your car while xe esp was a full model sort of thing
TerroristGHIA
PostPosted: Fri Feb 15, 2008 7:08 pm    Post subject: Reply with quote
The ESP was an option, it stood for European Sports Pack. We had a 351 4 speed XD in silver.scheel seats,Globes, full Fairmont Ghia pack when i was a little fella first geting into cars. Sort like what i am trying to achieve with my EF Mont Ghia.
Brett
Milesy
PostPosted: Sat Feb 16, 2008 8:07 pm    Post subject: Reply with quote
hey guys, sorry i haven't been on for a while
Yeah i'll try to take some photos. cant say how well they'll turn out tho, my camera isn't to high quality..
Milesy
skootin
PostPosted: Sat Feb 16, 2008 9:48 pm    Post subject: Reply with quote
Yeah the XD ESP is the best car ive owned driven 351 top loader and disc brake 9" LSD with the factory traction bars over the top of the diff.
I brought it when Mod PLates 1st came in and the dumb s**t mechanic tried tellin me that i needed to pay him for a mod plate for the factory modifications i made him ring FORD and they told him it was all std haha he wasnt happy he thought he was gettin my hard earned cash for the new mod plate scheme that QLD transport came up wit.
That ESP would come out of a corner sideways and no body roll wat so eva and lave 2 black lines down the road.
[47 queries :: 0.05309 seconds ]
