xd hybrid get's new interior
Warlock
X-Series Moderator & Cruise Moderator
PostPosted: Wed Jan 12, 2005 8:14 am    Post subject: xd hybrid get's new interior Reply with quote
almost finished putting my new ZL interior into my xd. it was alot bigger job then i thought (still need to cut and weld my door's to get the door trims on grrrr) and there is also alot of rewiring needed. huge thank's to grand master Stew at Smash Palace auto dismantlers who supplied the interior and is helping with it's instalation.
has anyone else done this mod? if so what little prob's did you run into?
Interceptor
PostPosted: Wed Jan 12, 2005 5:53 pm    Post subject: Reply with quote
wtf do you have to cut and weld?
Happy
PostPosted: Wed Jan 12, 2005 5:57 pm    Post subject: Reply with quote
post some pics up if you have digi camera available!!
smoke_
PostPosted: Wed Jan 12, 2005 6:56 pm    Post subject: Reply with quote
the metal strip that holds the longer arm-rest on has to be welded.
i've got this problem at the moment, but cbf doin anything abou it.
Warlock
PostPosted: Thu Jan 13, 2005 6:50 am    Post subject: Reply with quote
like he said where you srew the arm rest handle on there is no metal on xd and zl's have speaker's in the door need to cut door to allow this
Andrew J
PostPosted: Thu Jan 13, 2005 2:25 pm    Post subject: Reply with quote
Shouldnt be too hard to do. Just make sure the window is up when it gets welded. The door panels arent terribly thick, and if you manage to burn a hole through then, youll need new door glass. Oh, and remove anything that looks like it will catch on fire. Chances are, it will icon_razz.gif
So wheres the pictures mate?
Warlock
PostPosted: Thu Jan 13, 2005 10:15 pm    Post subject: Reply with quote
i have no camera it look's like i will also need to change the internal door handles
xr8 dismantler
Commercial Sponsor
PostPosted: Thu Jan 13, 2005 10:41 pm    Post subject: Reply with quote
just use a strip of sheetmetal and screw or bolt it into place. you can then attach you inside grab handle to that.
Warlock
PostPosted: Sat Jan 15, 2005 1:07 am    Post subject: Reply with quote
gonna spot weld the bit im cutting out for the speakers up to where i need metal for handle
gilesie
PostPosted: Wed Jan 19, 2005 6:47 pm    Post subject: Reply with quote
On the XE the back doors require a small strip of flat welded in to accomendate the two front screws of the handle and the front doors already have the holes for the speakers
atleast that is all mine required.
gilesie
PostPosted: Wed Jan 19, 2005 6:54 pm    Post subject: Reply with quote
As far as the electrics are concerned use the zl window loom and make an adaption cable to join the two looms (assuming that you are still useing the original loom and dash setup)
If you decide to use the zl traficator you need to make up a special loom addapter with a couple of relays for the headlights
Warlock
PostPosted: Thu Jan 20, 2005 2:58 am    Post subject: Reply with quote
looms are all done used the door looms from zl and made new looms out from doors. front doors do not have speaker holes they hadn't even thought about front door speakers in xd/xe front door's also need the metal strip icon_biggrin.gif
smoke_
PostPosted: Thu Jan 20, 2005 6:30 pm    Post subject: Reply with quote
my old doors are off an xe, they have speaker holes in it, im sure, unless those doors were once off an xf, lol.
xr8 dismantler
Commercial Sponsor
PostPosted: Thu Jan 20, 2005 10:12 pm    Post subject: Reply with quote
late xe,s had the same doors as xf,s ford must have tooled up early and began production of the xf door during the XE's
Nigel
PostPosted: Fri Jan 21, 2005 7:11 am    Post subject: Reply with quote
I put the XF Ghia Door Trims into my Xd once. Not such a big job. To Get around that missing peice of steel, I riveted a replacement into the door.
Whole conversion too around 2 days including power window conversion etc etc..
Car looked awesome. The XF Ghia had Tan trims which were a much better suit for the XD.
Nigel
[42 queries :: 0.04603 seconds ]
