romp Fordmods Oompa Loompa
Age:20 Posts: 33 Joined: 10 Mar 2005 Location: Berwick VIC, Australia
Posted: Thu Mar 24, 2005 1:32 pm Post subject: XF needing engine, any suggestions |
| i have an XF sedan six and want to put new engine in it any suggestions |
Age:23 Posts: 2457 Joined: 07 Nov 2004 Location: geelong VIC, Australia
Posted: Thu Mar 24, 2005 1:40 pm Post subject: |
well, how much money do you want to spend and do you like challanges?,
you could just get a worked X flow for it, thats the simple option,
Converting it to V8 could be trouble since there was no XF V8 to do the transplant from (makes it hell to sort out the emissions gear)
or you could go a late model 6cyl/v8 from an e series car, but then you have a headache when it comes to the electronics.
have fun. |
Posted: Thu Mar 24, 2005 1:47 pm Post subject: |
I would just do the six up!!! Chuck a bit of $$$$ into her and it will go like the clappers  |
Posted: Thu Mar 24, 2005 1:48 pm Post subject: |
im 16 and dont have much money and i dont wana put to much money into it because its my first car so i guess it will prob b bout $3000-$4000
i wana work the six but i dont know if i can get as much power as i want out of it
i thought about putting a E series engine in it
but i have a small block v8 at home that needs some work so i thought that i could put it in
i dont wana have any problems with the emision laws or anythin like that
thnx |
Posted: Thu Mar 24, 2005 1:58 pm Post subject: |
| romp wrote: | im 16 and dont have much money and i dont wana put to much money into it because its my first car so i guess it will prob b bout $3000-$4000
thnx |
Dude your sixteen and its your first car and you dont want to spend much...... Ummm well forget about a V8 conversion or I6 with that much $$$$. You can easily make the x-flow six go alot better with about $4000.
Cam, Holley, Hi flow filters, performance igintion setup, 2.5 mandrel bent exhaust, Pacemaker extractors. For under $4000 you could get all of that done and you will most like gain a very good amount of power.
More than enough i should say!  |
Posted: Thu Mar 24, 2005 2:07 pm Post subject: |
Okay i dont mean to be mean but seriously there is no reason why you should have 5 topics on the same thing in different sections.
X series modifications section is fine to put this under  |
Posted: Thu Mar 24, 2005 2:09 pm Post subject: |
thats kool
thnx
what kinda power do u think it could get out?
where would i look for this kinda stuff? |
Posted: Thu Mar 24, 2005 2:11 pm Post subject: |
| sorry just trying to get replys |
Posted: Thu Mar 24, 2005 2:18 pm Post subject: |
Thats alrite, fortuntely for you i had an XF previously to my XR.
Well basically you get your performance Exhaust and headers (extractors) from any good exhaust store, Cam, ignition, filters and holley can all be purchased at most Car stores such as Repco and Sprint Auto parts (they can order it all in for you) then just get a mechanic to hook it all up for you.
Expect up to about 20rwkw gain from all of this, mabe more. Which on an XF will be alot better than standard.
Good luck |
Age:27 Posts: 6702 Joined: 09 Nov 2004 Location: Wollongong NSW, Australia
Posted: Thu Mar 24, 2005 2:42 pm Post subject: |
| Didn't I just see this same post in the V8 section. i must have been the only one to reply to it over there. |
Posted: Thu Mar 24, 2005 3:07 pm Post subject: |
It's been posted in the 6 cyl, V8 and forced induction forum as well as here. It is annoying but I can sort of understand the reasoning.
| XRFan101 wrote: | Okay i dont mean to be mean but seriously there is no reason why you should have 5 topics on the same thing in different sections.
Not everyone reads every forum so by posting it across several related forums increases your chances of getting a response as well as getting responses on the widest array of potential options. The *big* problem is that every additional repost takes additional space in the database. What would be cool would be if the forum software gave you the option to have a single copy in one forum along with "ghost" copies in other, related forums that link back to the original. That way you could ensure everyone you want to ask could see it without taking up too much additional space in the db. Unfortunately, it's probably unimplementable due to abuse concerns, how to handle bumping in one forum (you wouldn't want each ghost to bump if it were only bumped in one forum for example) etc... |
Posted: Thu Mar 24, 2005 5:53 pm Post subject: |
| LSD wrote: | It's been posted in the 6 cyl, V8 and forced induction forum as well as here. It is annoying but I can sort of understand the reasoning.
Okay i can see where your coming from... Ne way his question has been answered so yeah.  |
smoke_ Cruise Moderator
Age:24 Posts: 5827 Joined: 05 Nov 2004 Location: Brisbane QLD, Australia
Posted: Thu Mar 24, 2005 7:22 pm Post subject: |
is it efi or carby? auto or manual?
if it's auto, get a 5spd.
get the whole block rebuilt, get a worked head/cam, extractors/exhaust (possibly cat if it's post 1986).
all depends on what you want to spend, in a recent street machine there was a turbo kit for the 4.1L that is basically bolt-on and it was around $2000. |
Posted: Thu Mar 24, 2005 7:31 pm Post subject: |
| smoke_rubber wrote: | is it efi or carby? auto or manual?
It was a supercharger kit from castlemain rod shop - using one of those toyota sc14 blowers, price was $1800 visit their website for more info |
Age:31 Posts: 1974 Joined: 08 Mar 2005 Location: East Kurrajong NSW, Australia
Posted: Thu Mar 24, 2005 8:19 pm Post subject: |
| Or for even more power .. drop in a 1JZ-GTE (2.5L straight 6 twin turbo ... 206kw from factory) from a Toyota Soarer ... and convert it to single large turbo .... much more power ... and a much stronger motor (capable of 700hp on standard internals). |
Posted: Thu Mar 24, 2005 8:26 pm Post subject: |
| yeah i meant supercharger kit, that was a typo, but either way, a turbo would get you goin quicker. |
Posted: Thu Mar 24, 2005 8:47 pm Post subject: |
its got a carby and its manual
wat sort of internal stuff is there out there? |
Posted: Thu Mar 24, 2005 9:46 pm Post subject: |
| how much power do you want? |
Posted: Fri Mar 25, 2005 9:10 am Post subject: |
Seriously for the money hes planning to spend there is no point in enigne swapping. I mean you got to get all the emmisons right and it has to be certified and if it doesnt pass then he gets pulled over by the coppas. Then they see that its got a foreign engine in it, no engineers certificate then its bye bye first car.
I personally would just put some work into the carby six As its been said Exhaust, extractors, Cam, Holly, Upgrade all the ignition system, and mabe try to add CAI somehow (cold air induction).
You will get good power gains just from doing what is sated above  |
gilesie Fordmods Oompa Loompa
Age:46 Posts: 29 Joined: 02 Dec 2004 Location: Cranbourne VIC, Australia
Posted: Fri Mar 25, 2005 8:08 pm Post subject: |
Your 16 and I dare say either no or little experiance at operating a motor vehicle so therefore I would recomend repair whatever is wrong with your car and spend the rest of the money on driver education,
In a few yers time you will end up getting a more powerful car and atleast thisway you will live long enough to enjoy it |
