Age:24 Posts: 1846 Joined: 25 May 2006 Location: Perth WA, Australia
Posted: Wed Feb 27, 2008 6:22 pm Post subject: |
When Only the best will do eh Matt, lol.
Hopefully we wont end up seeing the phoon motor in the EF, be a shame when the ute has come along way.
Just out of curiosity, is it pretty straight forward with the speed into the ute? |
Tocchi Cruise Moderator
Age:21 Posts: 902 Joined: 22 Aug 2006 Location: Perth WA, Australia
View User Gallery (20)
Posted: Wed Feb 27, 2008 7:48 pm Post subject: |
nah the EF is has turbo-certs, so thats road legal as is... and staying that way
plus the ute weighs 1465kg (stock) .. but im stripped a heap of weight out of it.. so its gonna be much lighter
"pretty straight forward with the 6 speed(?) into the ute?"
just cut floor, custom crossmember, modify tailshaft |
Age:40 Posts: 5293 Joined: 18 Apr 2005 Location: Hobart TAS, Australia
Posted: Wed Feb 27, 2008 9:05 pm Post subject: |
Ahh, kiwi's aye. if you wanna find the most radical of engine transplant, you find it at land of the long white cloud. when I use to stay there, I've seen a high rise tunnel ram Chev 454 powered Vauxhall Viva. tubbed & anchored down on custom tubular chassis, a 302 mini copper, a 350 chev 1969 toyota corona. you name it.
a matter of fact, I use to own a metallic blue 400 Cleveland powered 1968 toyota toyota crown deluxe. went through 3 toyota diffs when I owned it lol
The law is probably more strict now but man, those kiwis made everything fit. lol |
Posted: Wed Feb 27, 2008 9:10 pm Post subject: |
| Tocchi wrote: | yet again the EF has managed to score more goodies ahead of the ute
EF turbo upgrade details
front A/R 0.70
front wheel: inducer = 66mm, exducer = 84mm
rear A/R 1.15
rear wheel: inducer = 50mm, exducer = 75mm |
surtees Fordmods Stock as a Rock
Age:22 Posts: 149 Joined: 19 May 2006 Location: Geelong VIC, Australia
Posted: Thu Feb 28, 2008 11:35 am Post subject: |
| mmmmmmmmmmmm nice hair dyer. you have some very nice toys. your ef sounds like its a bit of a weapon let alone what your ute will end up as. top job keep it up. |
Age:23 Posts: 1415 Joined: 08 Nov 2004 Location: Bunbury WA, Australia
Posted: Thu Feb 28, 2008 11:24 pm Post subject: |
| Hey matt, do you know for certain that the MoTec will suit the Ford DVCT? Just about every (decent priced) ECU manufacturer i have called bar MoTec (because i'm poor) has told me that their ECU's aren't programed to run the VCT actuator solenoids. |
revhead_88 Fordmods Parts Gopher
Age:20 Posts: 79 Joined: 15 Mar 2006 Location: Canberra ACT, Australia
Posted: Fri Feb 29, 2008 7:42 am Post subject: |
| yes the motec m800 can run the DVCT. its one of the only ecu's that can |
Posted: Fri Feb 29, 2008 9:12 am Post subject: |
Dang it! Why does it have to be so expensive then?  |
Posted: Thu Aug 07, 2008 2:42 pm Post subject: |
yeh. did this yesterday and today
clearance on K-frame FTW
Age:19 Posts: 4284 Joined: 02 Mar 2006 Location: Port Lincoln SA, Australia
Posted: Thu Aug 07, 2008 3:13 pm Post subject: |
| did that just slot straight in? |
glenneaux Fordmods - Getting Side Ways
Age:22 Posts: 1270 Joined: 05 Apr 2005 Location: Burwood Nights VIC, Australia
Posted: Thu Aug 07, 2008 3:26 pm Post subject: |
| Tocchi wrote: | haha MICKY, it is stored in a pinky/red bubble bag
its a $300 'upgrade' to get the DVCT function enabled.
this one has:
- advanced functions enabled (launch control, traction control, and all other stuff)
- 5 bar map sensor
- sensor plug kit
- air temp sensor plug kit
- 34 pin 26 pin gold box
etc
and more importantly, now i can run my BA/F dash cluster  |
a BA/BF ECU run a BA/BF cluster, and i think its easier to get running than a motec  |
Posted: Thu Aug 07, 2008 4:27 pm Post subject: |
alfy, sure did
i used XG engine mounts & brackets
glenn, im not using a BA dash anymore
the interior is getting completely stripped, there will be no dash, just steering wheel, and a Motec SDL (sports dash logger)... rrp $2695  |
Steady ED Fordmods Addict
Age:22 Posts: 7064 Joined: 01 Jun 2005 Location: Melbourne VIC, Australia
Posted: Thu Aug 07, 2008 5:00 pm Post subject: |
Needs more torque power bellhousing and transbraked C9  |
Posted: Thu Aug 07, 2008 9:07 pm Post subject: |
it bolted STRAIGHT IN
i used the XG brackets and mounts. fitted perfectly
bonnet clearance / fouling (the XB GT bonnet bulge will fix that)
firewall clearance
plenty of room for a big radiator and thermos
Posted: Thu Aug 07, 2008 9:38 pm Post subject: |
Would cutting out the bracing on the bonnet give you much more clearance? It looks like it's a pretty big lump.
Also WTF is that...thing...on the oil filter? Is that a water fed oil cooler? |
Posted: Thu Aug 07, 2008 9:42 pm Post subject: |
yep it sure is. good way to keep the oil cool
yeh removing the bracing would probably have the engine just touching (or missing) the top part of the bonnet.
but under load it would hit.
so the XB GT bonnet grafted on will work |
Posted: Thu Aug 07, 2008 9:53 pm Post subject: |
| Is it stock!? I never knew they had them! You learn something new every day. Where is the water fed from and where does it drain to? |
Posted: Thu Aug 07, 2008 10:15 pm Post subject: |
yep stock F6 motor that i know of.
one goes to the thermostate, the other goes to the water pump. iirc |
Posted: Fri Aug 08, 2008 5:10 pm Post subject: |
as you can see, the XB GT bonnet has a sizeable bulge
this should be suffice to clear the motor
Posted: Mon Aug 11, 2008 6:24 pm Post subject: |
ok i got busy last night.
started to remove the interior. also removed the engine looms (to modify) and the main body loom was removed.
also ive been testing the different paths i can use for the belt. unsure which is the best route.
since the crankshaft and waterpump need the most belt coverage, and the power steering needs the least
