jsumner Fordmods Newbie
Age:23 Posts: 2 Joined: 04 Mar 2008 Location: Traralgon VIC, Australia
Posted: Tue May 13, 2008 6:11 pm Post subject: XG ute fan |
Hey guys,
Im looking at buying a 94 XG 'S'.
One of the few problems I have found with it is that when the interior fan is turned on air only comes out through the demister vents at the windscreen regarless of where you have selected.
The air con still works s**t hot, as does the heater. Any help would be greatly appreciated.
Cheers |
84_Fairlane Fordmods Stock as a Rock
Posts: 153 Joined: 23 Sep 2006 Location: Wodonga VIC, Australia
Posted: Tue May 13, 2008 8:31 pm Post subject: |
| will be something up with the vaccume switching system, check all the hoses that go through the firewall are connected, behind the glove box and then the switch's them selves |
xhi6ho Fordmods Oompa Loompa
Age:21 Posts: 47 Joined: 31 Jan 2008 Location: Camden NSW, Australia
Posted: Tue May 13, 2008 10:38 pm Post subject: |
| i have aso had this poblem with my xg, also think it could be a vaccume problem because it only happens to me when the motor is under load. let me know if you find out how to rectify this.. |
Age:18 Posts: 3480 Joined: 02 Mar 2006 Location: Port Lincoln SA, Australia
Posted: Tue May 13, 2008 10:43 pm Post subject: |
| my EL does that, but only when i put my foot down. |
Milesy Fordmods Oompa Loompa
Posts: 31 Joined: 28 Jan 2008 Location: Howlong NSW, Australia
Posted: Wed May 14, 2008 11:35 am Post subject: |
yeah i've got the same problem with my XH.
I'll be interested in this being rectified also, tonight i'll check the pipes going thru the firewall. |
Posted: Wed May 14, 2008 8:17 pm Post subject: |
| sounds like vacuum supply issue guys! |
xf_man Fordmods - Getting Side Ways
Age:30 Posts: 605 Joined: 21 Mar 2005 Location: Woori Yallock VIC, Australia
Posted: Thu May 15, 2008 4:54 pm Post subject: |
| When the motor is under load and there is a vaccum problem the heater/aircon will default to the windscreen - yes it is a vaccum problem within the dash - could be any of the controls within the dash |
mr_sperm1 Cruise Moderator
Age:21 Posts: 2523 Joined: 28 Jun 2005 Location: Hobart TAS, Australia
Posted: Thu May 15, 2008 11:22 pm Post subject: |
indeedy it is a vacuum problem.
my xh on gas was leaking from the back of the intake as each time it backfires it shoots the hose for the vents off! |
Posted: Thu May 15, 2008 11:25 pm Post subject: |
| xf_man wrote: | | When the motor is under load and there is a vaccum problem the heater/aircon will default to the windscreen - yes it is a vaccum problem within the dash - could be any of the controls within the dash |
oh great lol, the last thing i want to do is pull apart my Ghia dash to find a vacuum leak haha |
Gavsed Fordmods Parts Gopher
Age:18 Posts: 74 Joined: 12 Jan 2008 Location: bacchus marsh VIC, Australia
Posted: Sat Jun 07, 2008 4:44 pm Post subject: |
i had this problem and i found the "christmas tree" on the back of the inlet manifold is were the vacumn hose is it used to shoot off it also effects you engine and causes slight misfire re -connect hose and you should find it workig properly
cheers hope this helps |
