squeak81 Fordmods Newbie
Age:27 Posts: 8 Joined: 08 May 2008 Location: Beaudesert QLD, Australia
Posted: Thu May 08, 2008 7:17 am Post subject: xg ute with au motor and auto |
Hi I'm new. Well long story short i bought myself a 1993 xg ute which had a 1999 au motor and tranny. My question is i was told the au sump had rods going throu to the bottom end of the motor. The bloke i bought it off stuck the original sump back on so he didnt have to change the sway bar. Does any one know about these motors??
Also having probs with the tailgate latch. The left rod came off so i ordered the plastic clip and was wondering which way does the rod go on? |
Posted: Thu May 08, 2008 5:06 pm Post subject: |
| Well i found out from ford themselves that the only difference in the au sump is it's alloy. so now i can drive the ute knowing i won't do any damage to the motor. I also fixed the tailgate. |
Krytox Technical Contributor
Age:29 Posts: 2385 Joined: 20 Mar 2005 Location: Seaford State: VIC, Australia
Posted: Thu May 08, 2008 5:32 pm Post subject: |
The AU sump is alloy, it has Horizontal bolt holes going through to the end caps, making the bottom end stronger. and less vibration.
You can cut and shut the front of the original sump to clear the sway bar and or cross member in E series. |
Posted: Thu May 08, 2008 5:35 pm Post subject: |
| Ok thanks. Does any one know any thing about 'pinging' in a au motor. The first thing we are going to do is check the timming. Any thing else to check? |
xhi6ho Fordmods Oompa Loompa
Age:21 Posts: 46 Joined: 31 Jan 2008 Location: Camden NSW, Australia
Posted: Thu May 08, 2008 9:46 pm Post subject: |
| just a quick question... does the motor have the origional xg sump on it? |
Posted: Thu May 08, 2008 10:18 pm Post subject: |
| Yes it does. The man who i bought it off did the mod and decided to use the xg sump instead of the au sump as he didnt want to swap the sway bar over. |
