ambrose Fordmods Stock as a Rock
Posts: 136 Joined: 12 Jul 2005 Location: Geraldton WA, Australia
Posted: Wed Apr 30, 2008 3:52 pm Post subject: xh ute engine |
| if i want to put an ef engine in and take out the xh would i have to change the emc engine management computer or would it go straight in |
naughtyfalcon Fordmods - Getting Side Ways
Age:40 Posts: 1624 Joined: 13 Aug 2005 Location: Grafton NSW, Australia
Posted: Wed Apr 30, 2008 6:49 pm Post subject: |
umm,emc?
do you mean ECU,if its the ecu then you cn run the el engine no worries.
no need to change ecu's |
Krytox Technical Contributor Donating Member
Age:29 Posts: 2383 Joined: 20 Mar 2005 Location: Seaford State: VIC, Australia
Posted: Wed Apr 30, 2008 7:27 pm Post subject: |
| You can put it straight in, change over the synchronizer for a distributor, and retain all your other bolt ons. |
Posted: Wed Apr 30, 2008 7:30 pm Post subject: |
| oh yeah,forgot the synchroniser |
Trikee Fordmods - Smokin em up
Posts: 263 Joined: 02 Aug 2005 Location: brisbane QLD, Australia
Posted: Wed Apr 30, 2008 8:19 pm Post subject: |
| will have to get an el ecu to run the vacuum solenoid for the butterflies |
Posted: Wed Apr 30, 2008 8:22 pm Post subject: |
| only if he uses the bbm. |
Posted: Wed Apr 30, 2008 8:30 pm Post subject: |
| some XH's have a BBM! |
Posted: Wed Apr 30, 2008 9:35 pm Post subject: |
if he's already got the bbm then the ecu will already be equiped to run it.
but id he has the log manifold then he can just bolt it all up. |
Posted: Thu May 01, 2008 1:32 pm Post subject: |
| i would realy like to run all the ef gear which means the bbm and the coil packs the xh just has the long mainafold |
Posted: Thu May 01, 2008 6:44 pm Post subject: |
you wont be able to run the coil packs. ef computer has 120 pin ECU.
only xh xr6 came with bbm.
so your best going with a distributor, and an EL ECU as it will plug straight in, and all you have to do is run the wire for the vacuum solenoid |
