xr6 turbo rebuild
henry95ef
PostPosted: Thu May 15, 2008 11:51 am    Post subject: xr6 turbo rebuild Reply with quote
hey guys
i am in urgent need of someone to rebuild the turbo on my 2003 xr6 turbo i am in qld and looking for someone close to do the work
any help would be greatly appreciated
thanks
shannon
Steady ED
Fordmods Addict
PostPosted: Thu May 15, 2008 2:12 pm    Post subject: Reply with quote
Out of interest, did the filter block and starve it of oil?
henry95ef
PostPosted: Thu May 15, 2008 2:34 pm    Post subject: turbo rebuild Reply with quote
nah i have a tendency to drive it like i stole it, and after i stalled it up at a set of lights and took off in a cloud of smoke it started ticking, my mechanic said its not the motor, my gearbox rebuild guy said its not the gearbox so i pulled off the exhaust running thru the dump only, u can hear the ticking echoing loudly from the dump and when u spin the impeller by hand u can hear it rubbing and ticking, my guess is a bent shaft or impeller fin
Tocchi
View User Gallery (18)
PostPosted: Thu May 15, 2008 2:41 pm    Post subject: Reply with quote
is the exhaust producing smoke?
if so, its the seals that are f**k.
and if the shaft is bent, then the seals would be displaced a tad, which would result in oil escaping past the seals and into the exhaust.. meaning white smoke again from exhaust
henry95ef
PostPosted: Thu May 15, 2008 2:52 pm    Post subject: turbo rebuild Reply with quote
thats the funny part no smoke and still boosts hard
henry95ef
PostPosted: Thu May 15, 2008 3:42 pm    Post subject: turbo rebuild Reply with quote
haha just removed turbo and found 2 broken studs...............
Dansedgli
PostPosted: Thu May 15, 2008 4:06 pm    Post subject: Reply with quote
An exhaust leak is cheaper to fix than a turbo rebuild! Lucky.
Steady ED
Fordmods Addict
PostPosted: Thu May 15, 2008 4:35 pm    Post subject: Re: turbo rebuild Reply with quote
Nizpro do inconel studs I think, the stock ones can loosen from heatcycling, and are meant to be tightened every service
ebs_4l
PostPosted: Thu May 15, 2008 8:16 pm    Post subject: Reply with quote
how does the broken stud explain the rubbing ticking noise you claimed you could hear when spinning the impeller by hand??
Steady ED
Fordmods Addict
PostPosted: Thu May 15, 2008 10:24 pm    Post subject: Reply with quote
tjb45
PostPosted: Thu May 15, 2008 10:45 pm    Post subject: Reply with quote
I've had this happen to a friend’s car, just goes to show that letting these things cool down before switching them off is a good Idea. Most of the turbo side of the oil supply line was also blocked.
Steady ED
Fordmods Addict
PostPosted: Thu May 15, 2008 10:53 pm    Post subject: Reply with quote
Yeah it's pretty common, it's not in the Ford service schedule to clean the supply filter apparently, you have to specifically ask for it.
Just like autos never need their fluid changed, good work Ford!
tjb45
PostPosted: Thu May 15, 2008 10:57 pm    Post subject: Reply with quote
When you say "Filter" are you refering to the bango fitting at the engine block? This one I saw was blocked at the turbo end only.
Steady ED
Fordmods Addict
PostPosted: Thu May 15, 2008 11:11 pm    Post subject: Reply with quote
Interesting, there is a screen filter at the block fitting, thats generally what causes the problems.
tjb45
PostPosted: Thu May 15, 2008 11:19 pm    Post subject: Reply with quote
I pulled all that apart and couldn't find any filter. All that was there was the bango fitting.. Do you have any photos of this "filter"
The oil had baked on the inside of the oil line where it runs past the hot side of the turbo and then along the top of the exhaust manifold. The turbo bango bolt was completly blocked with this burnt carbon looking oil.
I spent the best part of 2 hours trying clean out the oil feed line and gave up in the end. After spending all that time I still got small chunks of soild oil droping out of the line when I hit it on the ground.
Steady ED
Fordmods Addict
PostPosted: Thu May 15, 2008 11:44 pm    Post subject: Reply with quote
http://www.fordxr6turbo.com/forum/index.php?showtopic=32461
That covers it from start to finish, blokes taken pics, screen is inside the banjo fitting.
Doesn't sound like thats what cooked your mates turbo though, if it had baked on oil in the supply line and was clogged at the turbo end icon_confused.gif
tjb45
PostPosted: Fri May 16, 2008 7:58 am    Post subject: Reply with quote
I've seen that thread on fordforums. I wouldn't call that a filter screen. Its just the banjo fitting. If those holes are getting blocked I'd hate to see what’s happening to the oil supply holes for the big end bearings.
EBXR8380
PostPosted: Fri May 16, 2008 2:35 pm    Post subject: Reply with quote
BAD service .. Change the oil and main filter more often.. Use a good oil... BTW its about the same $$ to overhaul one of these turbo's as it is to buy a new one...Also too much oil supply to these turbo's will make oil push through exhaust seals... If not serviced these lines can block up... So the $40 you save by not changing oil etc... Will cost $2k or $3k easy..
Let it cool for for 30 seconds or so or cruise the last klmr before shutting engine off.. Running too rich and retarded can make turbo & manifold very hot....
Not on XR6t engines .. But the stud issue can be fixed with longer studs and 10mm or so spacer pipe to keep heat away a little ...Allows for some expansion ...
[45 queries :: 0.04888 seconds ]
