ZF Auto - "Flappy Paddles"
data_mine
PostPosted: Sun Jun 15, 2008 1:54 pm    Post subject: ZF Auto - "Flappy Paddles" Reply with quote
I've been working on and off for weeks on a secret project, now as it nears completion, I'm revealing to the Ford world.
Ever since I picked up my GT-P I wondered why Ford didn't offer steering wheel mounted shifting (like Tickford did with the T series, and other performance car makers do, even ones which use the same ZF transmission). So I set about researching how to go about doing it.
Initial research was based off the BTR4 speed tiptronic module, after realising the ZF uses a completely different system of communicating to the box, and some initial incorrect information that it uses the CAN bus I was left despondent thinking it'd moved "out of my league" (of electronics skills).
However I persevered and one lazy weekend, I pulled the shifter apart, and had a look at the tiptronic module. I realised there wasn't anything special or CAN related on the board, figured I may still have a chance.
Shifter unit, and control module
So multimeter in had, I poked and prodded, getting a feel for what the module does. It uses an array of hall effect switches (magnetic sensitive) activated by a magnet attached to the shifter itself, and some hex added ICs to light up the corresponding red LEDs to show the shifter location on the module, and for the tiptronic function send a combination of high/low signals over three wires to the transmissions TCU (computer). These signals are only used for the tiptronic function, and the Performance mode. The other positions (Park, Reverse, Neutral, and Drive) are determined from the transmission itself via the position of the cable operated shift selector.
So soldering iron, protoboard, and hook up wire in hand I set forth building something to emulate the outputs of the module. After trying to find the correct parts needed for the connectors to the module (they're not a common size or shape) I managed to find them from a place that'd sell them in small batches, not the bags of 1000 the manufacturer wants to sell. Today, after a small set back, with my initial mapping of the signals needed (I got one of them backwards), resulting in a quick rewire of the protoboard I've had success.
Hooked up in between the cars loom (to the transmission) and the control module, I can control up and down shifts from the new micro switches.
Protoboard control module and micro switch modules
In line with the rest of the car, I've made the paddles up from carbon fibre.
Carbon fibre paddles attached to the micro switch modules
All that's left now is to affix the micro switch modules to the steering column (I've and idea for that, but some trial and error will be needed to figure out something daily usable).
nicco
PostPosted: Sun Jun 15, 2008 5:02 pm    Post subject: Reply with quote
f**k yeah man, thats awesome. well done
so this will leave you able to use the t-bar to shift as well wont it? i imagine it will
data_mine
PostPosted: Sun Jun 15, 2008 6:03 pm    Post subject: Reply with quote
At the moment, I've disabled that, as I've added some protection circuitry (don't want to blow up the TCM or the shifter module while I'm playing around).
Version 2, already in planning will keep everything functional.
Disco Frank
PostPosted: Sun Jun 15, 2008 6:09 pm    Post subject: Reply with quote
hahah f**k awesome man!
this will be sweet to see!
i how with the paddles u will keep the in the same spot while the wheel turns around them
should be easy to make somthign up then
or see if u can find the paddles off another car?
data_mine
PostPosted: Sun Jun 15, 2008 6:19 pm    Post subject: Reply with quote
Version one has them stuck to the steering column - they don't move (I figure you should have your gears sorted before you turn in anyway).
Version two will have them mounted to the wheel.
jrfttf
PostPosted: Sun Jun 15, 2008 8:58 pm    Post subject: Reply with quote
that some good electrical engineering! Good to see someone who knows there s**t going about it and not some cowboy with no clue jsut f**k good stuff up!
look forward to seeing pics of the finished product!
Well done!?
BenJ
PostPosted: Mon Jun 16, 2008 5:27 pm    Post subject: Reply with quote
Will the same trigger mechanism also work to activate the BTR type shift electronics?
BenJ
data_mine
PostPosted: Mon Jun 16, 2008 5:43 pm    Post subject: Reply with quote
It'll only work on cars with the tiptronic feature already.
Currently then only one it'll work on is BF's with the ZF 6 speed. With some tweaking, I'm sure I can get it to work on the BA and BF BTR 4 speed.
The older cars, don't have the tiptronic feature I can tap in to. (unsure about the AU T series, they had wheel mounted buttons).
BenJ
PostPosted: Mon Jun 16, 2008 5:53 pm    Post subject: Reply with quote
What I was thinking is to use the module Muzza builds for those that have installed the BA shifter into the Eseries cars.
But not use the BA shifter. Just have a button that activates the sports mode, and then use the paddles to make the changes.
Any thoughts?
BenJ
data_mine
PostPosted: Mon Jun 16, 2008 5:59 pm    Post subject: Reply with quote
You'd be best talking to him about how he does his module. I haven't seen one, so don't know how it works.
Assuming however, it takes the input from a BA shifter exactly the same as a BA would, then yeah it's possible.
Nicko
PostPosted: Mon Jun 16, 2008 7:30 pm    Post subject: Reply with quote
Wow, amazing Work Data_mine!
look forward to seeing your version2
Timmeh
PostPosted: Mon Jun 16, 2008 8:39 pm    Post subject: Reply with quote
I reckon you could be on to making some serious cash from Ford if your business minded as well as being technically very proficient like you are.
66 coupe
PostPosted: Mon Jun 16, 2008 8:41 pm    Post subject: Reply with quote
I have designed units for the 4speeds quite a while ago, which when the gear lever is over in the performance mode, will allow you to use the std steering wheel buttons to change gears.
Lukeyson
PostPosted: Fri Jun 20, 2008 11:56 pm    Post subject: Reply with quote
I'm betting that the hardest part to get sturdy and reliable will be the flappy paddles themselves.
Nice work - now that it's out in the open!
Lukeyson
Lukeyson
PostPosted: Fri Jun 20, 2008 11:59 pm    Post subject: Reply with quote
Now that's a neat idea. First I've heard of it. No reason why it couldn't be adapted to the 6-speeds really is there?
Were these units commercialised - or was it a DIY job?
Lukeyson
data_mine
PostPosted: Sat Jun 21, 2008 12:05 am    Post subject: Reply with quote
Now reason it can't be used for the ZF too. My current plans are to add buttons to the wheel and make use of the cruise/stereo control circuits
At the moment, getting the paddles as they are 'useable' is certainly the most difficult part. That's why there's no installed pics yet. When I'm happy with them, I'll post pics. That may not happen.
TKFDXR8
PostPosted: Sun Jun 22, 2008 8:20 am    Post subject: Reply with quote
could you use the paddle/switch assembly from another manufacturer who make them, ie. lotus, audi. I know expensive, but may give you ideas.
Froudey
PostPosted: Wed Jun 25, 2008 7:37 pm    Post subject: Reply with quote
got any pics on the wheel yet...
i have driven a sv6 with flappy padals and seem awkard changing gears while turning.. is your setup something simialir
66 coupe
PostPosted: Wed Jun 25, 2008 8:11 pm    Post subject: Reply with quote
Lukeyson
There were 3 units made that operated off the std BA wheel buttons, but thats as far as I went with it, because Im working other stuff.
Although it wont work on a BTR, Retrotek have pushbutton and wireless paddle controlled auto trans actuators. This means you do not have a gear lever at all, its all done by electronic buttons and the optional wireles paddles, I have installed a couple into hotrods and they work well.
data_mine
PostPosted: Wed Jun 25, 2008 9:32 pm    Post subject: Reply with quote
No, I'm not happy with them yet. That's a fault of my fabrication skills rather than my electronic skills. They work fine, just too flimsy, and I can't mount them securely with the design I made.
I'm working on adding buttons to the steering wheel, don't want to remove the functionality of the existing buttons, so I've got some work cut out, to try and multiplex in some extra signals.
[47 queries :: 0.07151 seconds ]
