T5 bellhousing/clutch compatability
Page 1 of 1 [ 6 posts ]
 Post subject: T5 bellhousing/clutch compatability
Posted: Wed Mar 05, 2008 11:42 am
Stock as a Rock
SA, Australia
Hi all
Need to change the gearbox in my EL. Its an EA/EB box with a 3 bolt (early style) clutch which is brand new.
Will a later model (EL) T5 work with this clutch?
Can I just change the gearbox and leave the bellhousing on the car?
Thanks
Posted: Wed Mar 05, 2008 11:45 am
Gallery: 11 images
Ride: EL Fairmont, VFR400 racer
Power: 144 rwkw
I believe you can. As far as I know, all E-series T5s and bellhousing are interchangable.
phong =P~
EDIT: by the way, clutch should be fine. Though it is a good idea to upgrade to a 6 bolt flywheel later down the track :D
phongus = Post whore 2006
EL XR6 motor, EL ECU + J3 chip, WADE 1673 Camshaft, 3" S/S intake, Pacy 4480, 2.5" Hi flow cat, 2.5" Lukey exhaust.
Max Power = 144.6 rwkw (03/05/2008)
Posted: Wed Mar 05, 2008 12:01 pm
Ride: ford falcon au3 xr8
just to confirm yes they all fit from ea to el..
the clutch size and flywheels are slightly different but they are all interchangable...
 Post subject: Re: T5 bellhousing/clutch compatability
Posted: Wed Mar 05, 2008 3:06 pm
Gallery: 8 images
Ride: 2007
Thanks
Yep.
BF Fairmont Ghia Series II update.
GQ XR6T ghia patrol.
,======o00o
//__|__|_,\_____\,___
|_/--\'_|'__|_/--\_[]IIII[]
_( o ) )_____( o ) )=o=) )__
Posted: Wed Mar 05, 2008 3:15 pm
Stock as a Rock
SA, Australia
sweet... thanks all
Stock as a Rock
SA, Australia
double post ftl
Users browsing this forum: No registered users and 13 guests
It is currently Sun May 27, 2018 7:21 am All times are UTC + 11 hours
