T5 Between Series
Page 1 of 1 [ 5 posts ]
 Post subject: T5 Between Series
Posted: Mon Aug 29, 2005 1:00 pm
Gallery: 1 images
Ride: Mini Cooper S Supercharged
Hello All.
As some of you may know, I have been planning to convert my auto EL into a manual EL. But, I just have a few more questions before I start buying the gear.
Firstly, I have heard that all T5's will bolt onto the back of the EL I6. So basically, For exapmle, An EB T5 Will bolt straight up. True Or False??
If this is true, Is there any major differences between the boxes. Like, were any of them built with problems or were they all built the same. It dosent matter about the age as basically, the box will be purchased and then dropped of to get re-conditioned.
Also, Who makes a mean flywheel. I want to put in a really nice, Light weight racing flywheel. Does any one know of any really good ones? I have heard that Mal Wood makes a nice one but have never seen one.
Any comments would be helpful
Thanks Guys and Gals
Posted: Mon Aug 29, 2005 8:34 pm
Gallery: 4 images
Ride: EL Futura
SA, Australia
Im no expert in the matter, as i got a factory manual. But i believe that any i6 t5 will bolt up to any i6. Just the ratios are a bit different between the models.
5 Speed EL Futura
Stock as a rock*
A1 Oils - Synthetic lubricants: www.a1oils.com.au
* A rock that has been Alted
Posted: Mon Aug 29, 2005 8:41 pm
Gallery: 4 images
Ride: Lincoln LS, MKII Escort, ED
and EA boxes dont have reverse synchro
Because i can.
Posted: Tue Aug 30, 2005 10:19 am
Gallery: 4 images
Ride: EL Manual
The boxes were improved continously througout their life.
Significant changes were made after EA- (early)EB to improve durability.
EF-EL may have gotten revised syncro's.
V8 boxes had stronger internals and different gear ratio's but wont bolt up to 6's without different input shaft.
XR6 turbo boxes were the strongest but will need modification to fit a pre-BA car. (removal/conversion of clutch mechanism and different input shaft).
Manual EL Gli.
Mods: Crow Stg3, Chiptorque Dynotune. Lukey Exhaust. DBA slotted rotors, EBC Pads. Whiteline Low Susp. EL GT Swaybars, ROH Envy 17 x235 wheels. Vehicle Datalogger Display V2.0,
Posted: Tue Aug 30, 2005 12:42 pm
Gallery: 1 images
Thats exactly the info i was after. What box would go well with the auto's diff?
Users browsing this forum: No registered users and 25 guests
It is currently Sat Apr 20, 2024 5:01 pm All times are UTC + 11 hours
