jonathon |
would a t5 gearbox out of eb - ed fit in to a 1982 xe ute and will things need to be changed
ute is currently a 4.1 carb, with a single rail 4 speed, diff is a zh fairlane lsd any helpers plzzz thanks
_________________ Owning 1 of 84,847 ebII. |
keithParker |
you would need the t5 belhousing to suit an x series, an e series one wont fit.
I have a t5 with xseries bellhousing here i need to get rid of, so make me an offer and it's yours, however I'm in sydney, where are you? |
jonathon |
the vehicle is in mildura victoria
stubbsy351 |
everthing is the same , except bellhousing and gear box mount. these are available from www.rodshop.com.au for about $300 new(bellh) and brackets are also available from ford brand new for about $25 (i think they still sell them, bought mine about 3 year ago)
raa4.0L |
you can use a 4spd borgwarner bell housing off an xe or xf and i think the box has provisions for the mounts off the 4spd and everything else should be the same.
i had this setup in my xf
_________________ Holden's are a phase you go through then you grow some nuts and buy a FORD!!!!!!![/u] |
Users browsing this forum: No registered users and 37 guests |
