Fordxf351 |
hi guys, I just got hold of a conversion for my EB my question is that the box come out of a EL/EF will the bell housing mount to the EB engine 4.0L MPI also the pedals are from the same model .I thought i would ask before i went to the trouble of pulling my auto & finding things don't fit..lol
the stuff i got with it is listed so u all know exactly what i have. T5 complete with flywheel clutch & preasure plate EF/EL bellhousing Tailshaft Clutch Cable EF/EL pedalbox EF/EL Manual ECU & box wiring harness for $300 bucks mates rate's so couldn't pass it up |
phongus |
Box and tailshaft should fit just fine. Pedal box won't fit...but I think you can use the pedal with a malwood pin kit. ECU and harness won't be useful unless you're running EF/EL engine/BBM.
Also EF and EL ECUs are totally different and are not interchangeable. So if you do resell the ECU...make sure you know if it's an EF or an EL. I am not 100% sure on the clutch cable, but it should fit.
_________________ phongus = Post whore 2006 |
Fordxf351 |
thanks phongus,
sounds good ,i can handle the ecu not being interchangable ill just use the auto one with the ecu mod i found on here . pedalbox well easy enough to mod if i cant get hold of a ea-ed manual one ..so yeah sounds like i got some work to do thanks again mate |
Users browsing this forum: No registered users and 37 guests |
