RIDDO |
hi there, I have been looking for a related thread but given up as they all seem to be about 6 cyls, so is there anyone out there who could help with my conversion.
Transplanting 5L into xf and using an xg ute T5 with a dellow bellhousing when i order it. Iwould like to know what i have to or can use from the xg stuff such as flywheel and clutch etc, and what mods have to be done to the wiring on the 5L side to accommodate the T5. do I have to use a manual ecu to overcome 'limp' mode what are the problems when doing this conversion, any help will be greatly welcomed... thanks |
Froudey |
I is the XG T5 of a V8 or I6,,,, cause i have read and apparently the thrust shaft(the shaft that goesinto the bellhousing) is either shorter or longer in the 6 compared to the 8..
If the 5L is carby shouldn't have no dramas with manual gearbox ecu etc etc but if it is a fuel injected ones i assume it would be a early one that had a 3 speed auto... as the 3 speeds had no TCM so you just need to source a manual loom.
_________________ R.I.P Tobias my son. |
RIDDO |
the engine is injected with a 4 speed ecu
RIDDO |
sorry the xg box is from I6. i have been told that the dellow bellhouding can fit the different length imput shaft off the I6 to go into the v8
Froudey |
oh ok i get ya know so in theory if the 8 crank bolts are the same pattern as the 6 crank i couldn't see a drama
RIDDO |
i'll have to have a look then
stockstandard |
they are different
RIDDO |
thanks, has anyone got a windsor flywheel forsale??
Froudey |
RIDDO wrote: thanks, has anyone got a windsor flywheel forsale??
mate post in the wanted section,,, and maybe buy a just parts or ebay???
Users browsing this forum: No registered users and 18 guests |
