deanxr |
what is everyone running in their T5?
I know Ford recommend ATF but after getting a quote on oil change and asking what they use he mentioned 75 grade gear oil, is it wise to go against whats in the manual? Car is a BF XR6 if that makes any difference. |
Stu5766 |
Age: 42 Posts: 78 Joined: 15th Jun 2010 Ride: XD Fairmont Ghia 351 Location: Blue Mountains |
I run ATF in my T5.
I would stick with what is specified. Cheers |
XFWAGON |
I run Castrol Transmax Z ATF in mine. Seems to do the job, and for the price, it should.
_________________ 1993 LTD V8 Oregon 5 speed "click me" |
TROYMAN |
i have used penrite sin 75 fully synthetic gear oil in my ea t5..it was fine..
and im now running castrol transmax z synthetic auto fluid in the ef t5 im using now.. both seamed to work fine... |
cjh |
Depending on the condition of the box, and being in a BA/BF, using a 75W- light gear oil, will make it hard to change gears when cold.
deanxr |
Thanks fellas, looks like i'll stick with ATF then.
cjh |
deanxr wrote: Thanks fellas, looks like i'll stick with ATF then. Just change it more often than what the service schedule says.....like every 20,000km...or if you give it a bit, every 15,000km......ATF is cheap compared to replacing g'boxes....yes?
Users browsing this forum: No registered users and 17 guests |
