JG33Replica |
Hi, can someone tell me if there is a difference in T5 gearboxs 6cyl and 8cyl. I want to put one in XE falcon with 351 windsor that puts out 400 bhp at the rear wheels. car is used for track days.
_________________ LOVE THE BLUE OVAL |
Matt_jew |
Input shaft is a different length. V8 is longer.
A six cylinder T5 can be fitted using a single rail bellhousing after some slight machining and redrilling. How long a T5 behind 400HP on the track is going to last is anyone guess.
_________________ xr6turnip wrote: More people paid for a ride in a VT commodore then an AU Falcon so the VT is superior.
Based on that fact my Mum is the best around! |
XR6AUII |
Matt_jew wrote: Input shaft is a different length. V8 is longer. A six cylinder T5 can be fitted using a single rail bellhousing after some slight machining and redrilling. How long a T5 behind 400HP on the track is going to last is anyone guess. i would say you wanna go a c4 upwards..While the T5 is "bullet proof" thtas only rated against a max of 187kw... 400 HP is a little more? |
Six |
T5 wouldn't last that long with regular track work, would be better off with a T56.
_________________ MGW Short Throw Shifter, CVE Cam, CVE Head, SS Big Mouth Air Intake, Pacemaker Headers, 3" Exhaust, 3" Varex, 3" Cat, 19" Silver Agents, EMS Stinger 4424, 42lb Injectors and Walbro 255lb Fuel Pump |
Users browsing this forum: Google Adsense [Bot] and 31 guests |
