t5 hard to get into reverse
Page 1 of 1 [ 14 posts ]
 Post subject: t5 hard to get into reverse
Posted: Sat Dec 27, 2008 7:34 pm
i have an ea 5 speed in my el and it is very hard to get into reverse
it does not crunch or grind when i pull the stick back its like reverse is not even there
i just keep putting it into another gear first and after a few tries it goes in
does anyone know what i could to fix this
all other gears go it fine
thanks
Posted: Sat Dec 27, 2008 8:47 pm
Gallery: 13 images
Ride: EF
ea box's didnt have syncros in reverse, its the price to pay for those nice short gears is an occasionaly crunch, i generaly grab 5th then reverse on mine, some times it does crunch a bit if not done right, also reverse seems VERY sensitive if the clutch cable nut spins on its own or somthing.
latest mod: A Service
MY BUILD THREAD
Posted: Sat Dec 27, 2008 8:58 pm
it doesnt crunch the stick just goes right back but its like nothing is there
it takes a few tries of putting it into another gear first before it finaly goes in
Posted: Sat Dec 27, 2008 11:02 pm
Gallery: 10 images
Ride: 96 XH/97 EL
Is the clutch adjusted correctly ??
Do all the forward gears select ok ??
Posted: Sun Dec 28, 2008 12:25 am
yes all forward gears work and clutch seems ok
Posted: Sun Dec 28, 2008 2:06 am
SA Cruise Moderator
Ride: Ford Ed
SA, Australia
Same thing happons in dads Eb He just double clutchs and it just goes in most the time.. Its mainly so u dont just slip into it..
Adelaide E Series
Posted: Sun Dec 28, 2008 6:57 am
Ride: 98 NL, 97NL, 98EL
Power: 141 rwkw
before you go into reverse, when your come to a complete stop, put it in third gear, and then reverse, something i learned at work with a ea box!!
Laticia
BANNED!!!!
Posted: Sun Dec 28, 2008 3:12 pm
will try 3rd gear first
is there any adjustment on the gearbox
Posted: Sun Dec 28, 2008 3:13 pm
Power: 141 rwkw
bingo!! :)
laticia
BANNED!!!!
Posted: Sun Dec 28, 2008 3:20 pm
Gallery: 8 images
Ride: AUII XR6 Uterus
5th to reverse works better i find, i think the no 5th-reverse lockout was factored into the t5 from the factory as no syncros makes it procedural to engage another gear first lol
Not to get technical, but according to chemistry alcohol is a solution.
Posted: Sun Dec 28, 2008 4:29 pm
Gallery: 1 images
Ride: Gli
Never had the pleasure of driving a EA T5 but if reverse doens't have syncro's then your not going to be able to put it in reverse while moving at all. It will just crunch or not go in. I drive trucks with non syncro box's and I find if you have your foot flat to the floor on the clutch while your trying to select reverse just start dropping the clutch slowly and the gear will select ( it will simply fall in).
Posted: Sun Dec 28, 2008 5:26 pm
Oompa Loompa
Ride: Pintara >:
I often have trouble with reverse with my 5sp. I just double clutch like what Ford-sxr6 said. Seems to work fine.
Posted: Sun Dec 28, 2008 5:29 pm
Ride: 93 ED sedan
Power: 161 rwkw
One of the reasons it maybe difficult to select reverse may be that the start of the spurs on the reverse gear set is worn/bluntened off.
This occurs from people not letting the g'box stop spinning before selecting reverse.
I replaced a few parts in my g'box and it selects reverse fine.
I select 1st before putting into reverse, no probs.
http://youtu.be/jJTh9F3Vgg0
Posted: Tue Dec 30, 2008 3:29 pm
Gallery: 8 images
Users browsing this forum: No registered users and 12 guests
It is currently Sun May 20, 2018 11:25 pm All times are UTC + 11 hours
