marxr8 |
Hi guys
I'm chasing 230 - 250 rwkw for my el 8, its got the t5 in it and im woundering if it's any good i will have to reco mine so im woundering will it be worth keeping it. to keep or not to keep Cheers
_________________ Thats a sweet ride you got there! don't tuch it, dont even look at it |
Fairmont_03_5.4 |
Not sure about the T5 boxes personally. But a T56 Tremec 6 Speed would defintely be able to handle that power.
_________________ Chaos, Panic and Disorder. My work here is finally done. |
krisisdog |
You'll probably break it, a reco wont help though as the case itself flexes.
Save up and throw a T56 in it when it pops. |
marxr8 |
thought so cheers guys
capare |
I'v got a Gforce t-5 going behind my el xr8 363 stroker, and il be making alot more than 250rwkw.
The key features of the Gforce t-5 is the aftermarket transmission case(which stops flexing), upgraded main shaft, 26 spine input and strong gears. And the best part about the Gforce box is you simply swap it over without mods. Cheers Matt |
MICKYYYY |
Geforce T5 is ur cheapest option for upgrade then u move on Tremec series boxes like the T56 and Malwood can help u out with conversion.
As the Aussie dollar is so good right now u should look into ur trans options as u can get both from the states......................... Sell ur T5 as a conversion as at least u get some money back instead of breaking it.
_________________ Wanted Either Capri/Cortina/XY/XW/XR/XT with tough V8 stroker engine, auto, 9inch, upgraded brakes etc[/SIZE][/size][/color] |
capare |
Ash wrote: I'll be putting a T56 in my AU as my 5th is on its way out in the T5. Something like this except the starter is on the R/H side. http://cgi.ebay.com/ebaymotors/Tremec-T ... ccessories I've seen T56's go for about $1500 in the US. Get it to someone exporting cars from the US and it should be a couple of hundred maximum to bring back in a container. You also have to consider importing duties $300?, brokeage costs $200? and delivery $100? (if not picking up the goods your self). So your $1500 (if your lucky) for a second hand t56 witch the condition is unknown will end up being more like $2100 then your shipping costs $500? total est $2600. then you have to get a custom bell housing $600?, Decent clutch $1500?, hydrolic clutch set up $800?, custom tailshaft $600?, new starter $325?, billet steel flywheel $500?, crossmember to suit $125? and theres always a few little thing to make it work. sor your looking at $4450$ Total for a seconhand t56 $7000?. Or you could call malwood and chuck a good 9 grand out your wallet. The T56 magnum is a great 6 speed and with a 700ft lb rating it will hold almost any street engine! New T56 Magnum with ratios of 2.66,1.78,1.3,1.0,.80,.63 built to suit the EB-EL application $5800 New Tremec Bellhousing $770 New sandwich plate $75 New starter $325 New ACE 11’’ Billet steel flywheel $495 New 11’’ High Performance clutch kit $890 New ARP flywheel bolts $75 New pedal pin kit $105 New Under Dash Hydraulic set up $790 New Braided line $160 New mount $43 New crossmember to suit $125 New gearstick $120 New gearstick knob $65 New slip yoke $175 New Floor Panel and Boot $45 New Console Insert $85 If you have any questions then please contact me again. Regards, Mal MAL WOOD AUTOMOTIVE 42 LYONS STREET WARWICK, QUEENSLAND AUSTRALIA 4370 07 46613548 In other words there is no cheap option,but there are options. Cheers Matt |
krisisdog |
T56 have been selling for 700-1000 on ebay.
comagutsa |
capare wrote: I'v got a Gforce t-5 going behind my el xr8 363 stroker, and il be making alot more than 250rwkw. The key features of the Gforce t-5 is the aftermarket transmission case(which stops flexing), upgraded main shaft, 26 spine input and strong gears. And the best part about the Gforce box is you simply swap it over without mods. Cheers Matt were and how much are these |
krisisdog |
Ash wrote: krisisdog wrote: T56 have been selling for 700-1000 on ebay. Locally? I think this one was down in Vic? I almost bought it. Dunno why youd bother with a G force, its still a 5 speed, and unless 3rd cog itself is larger you can still strip it. |
capare |
comagutsa wrote: capare wrote: I'v got a Gforce t-5 going behind my el xr8 363 stroker, and il be making alot more than 250rwkw. The key features of the Gforce t-5 is the aftermarket transmission case(which stops flexing), upgraded main shaft, 26 spine input and strong gears. And the best part about the Gforce box is you simply swap it over without mods. Cheers Matt were and how much are these Located in Pensilvania USA and cost aound AUD $4000 delivered inc all fees for importing. contact http://www.gforcetransmissions.com/tran_gt-5.asp they are excelent to deal with. Cheers Matt Last edited by capare on Wed Feb 02, 2011 3:33 am, edited 1 time in total. |
capare |
krisisdog wrote: Ash wrote: krisisdog wrote: T56 have been selling for 700-1000 on ebay. Locally? I think this one was down in Vic? I almost bought it. Dunno why youd bother with a G force, its still a 5 speed, and unless 3rd cog itself is larger you can still strip it. All gears are larger and are made from high nickle. and with the billet aftermarket case third will not budge with case flex. Cheers Matt |
krisisdog |
Still a 5spd
MICKYYYY |
krisisdog wrote: Still a 5spd Give us a good reason why he needs a 6 speed???
67RCE |
MICKYYYY wrote: krisisdog wrote: Still a 5spd Give us a good reason why he needs a 6 speed??? Becuase even a G-Force box will strip 3rd after it's been given enough. Go TKO or T56!
_________________ ILL60 - EF XR8, Sunroof, Ticky Kit, 19x8.5/19x11 TE37's, 347, AFr185's, TFS BoxRcustom converter, Hurst Quarterstick, huge billet cam. |
Users browsing this forum: Google Adsense [Bot] and 26 guests |
