ef_falcon_95 |
Today I was driving and in 4th and 5th gear when on part and full throttle I can hear a light grinding noise . It's coming from the gear shifter .
I was doing around 70-80km and when I'm Crusing , no throttle the noise is gone . On Saturday I put in penrite 75W80 manual gear oil , I put in 1.9L which is what the work shop manual says. Any ideas what's causing it ? Cheers
_________________ El XR6 Turbo |
bry40l |
i thought they are ment to run an auto trans fluid in them?
_________________ BF XR6 |
ef_falcon_95 |
They are but on the penrite website it says this can replace the auto fluid .
I think I'll drop the penrite and put in dextrol 3 ive read it's what supposed to be used
TROYMAN |
mainshaft bearing on there way out???
bry40l |
ef_falcon_95 wrote: They are but on the penrite website it says this can replace the auto fluid . I think I'll drop the penrite and put in dextrol 3 ive read it's what supposed to be used did you notice it got harder to shift or any shinanigans like that? youd think if it was the wrong stuff youd feel it when shifting etc..
ef_falcon_95 |
Still feels the same shifting wise .
Been reading many threads and most people use castrol transmax z. I didn't make noises before the oil change so I'm thinking it don't like the penrite
evxr6 |
Sorry to hi-jack, but I have read you are meant to put Lubrizoil 7906 in with the Dex III. Why and how much?
_________________ Current ride: MY03 Liberty RX Wagon |
Troy |
i used castrol vmx80 and it's fine, maybe add some additive?
ef_falcon_95 |
What additive should I use with penrite ?
Troy |
never tried it myself but Nulon G70 sounds alright
Krytox |
Penrite 75/80 is fine, I ran my T5's with that for years, Yes I added lubrizol.
Since then I only run Transmax-Z (with NO Lubrizol. Saying its grinding in 4th Gear is something not to be ignored. There is only 2 bearings working under load, input shaft and main. If the box is noisey has done more than 200,000k's and it was mine, I would be replacing those 2 bearings (around $60) just for the bearings, and this is only preventative maintanance.
TROYMAN |
if the penrite gear oil is synthetic there is no need to add lubrizol,
i would use either the penrite syn 80 gear oil or castrol tranzmax z, both are synthetic so no need for lubrizol.. lubrizol is only ment to be added to mineral atf like dexron... the lubrizol is ment to stop the sincro rings from sticking/balking on gear changes. |
evxr6 |
TROYMAN wrote: if the penrite gear oil is synthetic there is no need to add lubrizol, i would use either the penrite syn 80 gear oil or castrol tranzmax z, both are synthetic so no need for lubrizol.. lubrizol is only ment to be added to mineral atf like dexron... the lubrizol is ment to stop the sincro rings from sticking/balking on gear changes. Thanks for the explanation T-MAN. How much of the lubrizoil per fill should go in if using dextron?
bry40l |
how many litres do they hold? Cant remember how much i put in mine but i wouldnt mind changing the oil again soon to something better
Troy |
1.9L
Users browsing this forum: No registered users and 23 guests |
