matt_xr6 |
just got a t5 put into my el fairmont, and the gearbox is making weird and wonderful noises especially in third, its exactly like gearbox wine except its much louder, and when it is inder load it sounds like something is loose within the box itself in any gear other then 1st...
any help would be great cheers matt
_________________ 1997 el fairmont, pedders superlows, 19" koya menis rims, manual...and more to come |
TROYMAN |
i can only suggest 2 things..
either there is not enough oil in the box.. or the box is just about stuffed and needs a re build... |
matt_xr6 |
how much oil do you recomoend that i should put in there...i might just flush the oil in it and give it a little bit extra with some conditioner
TROYMAN |
it only needs to be filled untill the oil reaches the filler hole in the side of the box..
thats about 1.9 ltrs.. if it has auto fluid in it? replace it with gear oil..this will help quieten the noise... otherwise it might be reco time!!! |
matt_xr6 |
screw reconditioning it...its under warranty so t hey should just be replacing it if its phucked
TROYMAN |
where did you get it from??? a wrecker???
matt_xr6 |
yeah got it from the wreckers in clontarf up here...honestly i dont think they even knew what they were doing cus they didnt even know they had to change the ecu
cjh |
matt_xr6 wrote: yeah got it from the wreckers in clontarf up here...honestly i dont think they even knew what they were doing cus they didnt even know they had to change the ecu Maybe the dudes at the wreckers are like this.. http://www.youtube.com/watch?v=4fD0QKsQdWA
matt_xr6 |
i really dont doubt that...considering most of the people that work there are all female lol
TROYMAN |
matt_xr6 wrote: i really dont doubt that...considering most of the people that work there are all female lol well that explans everything!!! |
matt_xr6 |
it does a bit...oh well the best part is that its under warranty so if the box is rooted then they will either have to get it reco'd or replace it with another one...the only problem with buying second hand stuff that you cant see inside of is you dont know if its good or not...
Grimketel |
I found gear oil was noisy, and auto fluid quiet on my tremec t5.
Gear oil is too thick for the t5, tremec specify auto fluid as gear oil can result in blocking ring damage (synchro's?) The gearbox I got second hand had gear oil in it when I drained it and ALL the synchros are rooted. It whines like a supercharger under load, and rattles at low rpm load. The tranzmax z I put in it made it a lot quieter but the damage was pre existing so its still noisy. Also I think my input shaft bearing and throwout bearing are up for replacement, as you can hear a dugger-dugger-dugger-dugger going on when in nuetral with the clutch out. engage clutch in nuetral and dugger noise goes quiet. I would say some form of rebuild is on the cards. Use transmax z in your t5. its the best stuff you can use.
_________________ enough isn't enough |
TROYMAN |
lol mine was the oposite..
i had trans fluid in mine and it rattled and whined like a b**ch.. so i am now using penrite fully synthetic gear oil and no more noise.. mine is a ea t5.... keep in mind its probably more a bandaid fix its only going to get worse... |
matt_xr6 |
ok so its not just me being paranoied lol cus you car is doing exactly the same thing...thanks for that
TROYMAN |
yea but keep in mind my box has done over 400.000kms.
eitherway if its under warranty try get a better one... |
Users browsing this forum: No registered users and 27 guests |
