T5 Oil
Page 1 of 1 [ 7 posts ]
 Post subject: T5 Oil
Posted: Sat Apr 23, 2005 9:12 pm
Ride: BA Falcon EGas
WA, Australia
G'day guys....I think its time to change my gearbox oil.
Now, coventrys says that the normal power steering oil or auto trans oil is the way to go but is their another product thats better for a modded car?
ie something made by redline?
BA Falcon Futura on EGas. Stock as...
EF 5 speed manual; PH 4480 Pacemaker Headers; 2 1/2" Lukey Mandrel Bent System; Hi Flow Walker Cat; Stage 3 Crow Cam; ChipTorque Chip; 3" Mandrel Bent Intake; K&N Pod Filter; Low Pedders Suspension; 17" EL GT Champagne Rims; RPM Series Clutch
Posted: Sat Apr 23, 2005 11:01 pm
Gallery: 5 images
Ride: 1994 ED Ricer
WA, Australia
im sure there is high quality stuff from redline or motul.
but you have a t5? i wouldnt waste my money on expensive gearbox oil..
i use the normal BP stuff and its fine!
Posted: Sat Apr 23, 2005 11:26 pm
Gallery: 12 images
Ride: 1994 ED XR8 Sprint
just use dexron 3 with the friction modifier.... f**k if i can remember what the additive is called tho
Banned
Posted: Sun Apr 24, 2005 12:12 am
Gallery: 10 images
Ride: 96 XH/97 EL
"Lubrizol 7906". Most parts shops should have it.
Posted: Sun Apr 24, 2005 3:23 pm
WA, Australia
Cheers fellas...
so there's no point getting the expensive redline stuff for the T5?
Posted: Sun Apr 24, 2005 9:23 pm
Ride: 2010 Nitro Blue FG
you can if you want,but theres no real point though. The T5 isnt the most advanced gearbox in the world. I just use the normal stuff plus a bit of additive and its a treat.
The boogieman checks under his bed for chuck norris
Posted: Mon Apr 25, 2005 1:48 am
WA, Australia
redline MTL is good have run it in my 5 speed with no probs,
but recently got car serviced and found out ford had changed out the gearbox oil to ATF, now its noisey as with whining gears, so add lubrizol 7906, mad no diff with noise but has made it a little easier to shift.
Im going to drain out the ATF s**t ford put in and put MTL back in with 7906.
Penrite aslo made a gear oil to suit these gear boxes as well, might be cheaper?" penrite extra light gear oil 75, have a look on the penrite website.
Hope this helps.
Users browsing this forum: No registered users and 16 guests
It is currently Sat May 26, 2018 9:44 pm All times are UTC + 11 hours
