TwinturboBMX |
3rd in auto should be 1:1 4th should be an overdrive, 4th in manual is 1:1 and 5th an overdrive.
_________________ 17" Tezza Steelies, King F**king lows, pedders sports ryders, 2.5" cat back exhaust, pacemaker extractors, T5 manual
ToranaGuy |
Pulled the speed drive cogs from both the Auto & manual boxes, they are both Green 21 teeth cogs. Forgot to check the diff while i was under the car.
Cheers ToranaGuy
_________________ I am the ToranaGuy!|74 Lh Torana Turbo|78 Hz PanelVan|86 Mighty Boy Ute|93 EB2 Ghia,GT Mockup,5spd,LPGI,Full Leather|2 x EB Xr8 5spd's|FS [VIC]: Wrecking - Eb XR8 - Parts available |Build Thread|Ebay Items - Ford Parts| |
prydey |
hmmm thats thrown a bit of a twist up then. do you have access to a gps or anything to check your speedo to confirm if it is reading right.
did you count the teeth on the cogs. i assume you did. i think there is a light green and a dark green though. if you didn't count the teeth, make sure they are the same. otherwise thats a bit weird if all you did was change the gearbox over. maybe the gear inside the box that the cog drives is different. i doubt it but just throwing up an idea. as mentioned a thousand times earlier, the overdrive ratio's are different but not enough to increase it by 400rpm.
_________________ eb v8: low loud and fast. just how a v8 should be. i guess the big question is, is it fast enough... |
RedRoo |
Age: 54 Posts: 1883 Joined: 22nd Apr 2005 Ride: 94 ED Fairmont, MY97 LE WRX Location: Seymour |
You'll find the speedo drive cog in the manual box is differant from the one in the auto.
You may just need to get a cog with lesser teeth to rectify the problem. |
ToranaGuy |
I did count the teeth on the cogs, and they also have the same part number on them.
I don't have access to anything that can accurate say what my speed is. I've gotta go out soon, i'll be taking the car for a test spin, i've just resolved an electrical issue that could possibly make the speedo & tacho read wrong. Cheers ToranaGuy
Gaz |
dunno if anyone had done the breakdown but here we go.
assuming 235/45/17 tyres --3.08 diff EB2+ box : 100km/h = 1829 RPM EA box : 100km/h = 1981 RPM --3.23 diff EB2+ box : 100km/h = 1918 RPM EA box : 100km/h = 2078 RPM --3.45 diff EB2+ box : 100km/h = 2048 RPM EA box : 100km/h = 2220 RPM those figures are worked out with an excel spreadsheet, so rpm's are about spot on, might be 1-2 rpm out
_________________ 2007 Steel BF Ghia MKII V8 - 19" GTP's + Superlows |
snap0964 |
choppadoo wrote: You'll find the speedo drive cog in the manual box is differant from the one in the auto. prydey wrote: maybe the gear inside the box that the cog drives is different. i doubt it but just throwing up an idea. The output shaft 'drive' gears are different colours - you'll find the BTR 4speed will most likely be white, the EA and later T5's seem to be a purple/maroon colour - I've found both have the same helical groove count.
The auto gear won't fit on a T5 output shaft - It'll be too loose. So the 'driven' gear should be the same for auto or manual, of course different diffs will vary this. I think you'll find in the EB that 3.27:1 is used, as 3.23:1 wasn't introduced til later, perhaps EF/EL (correct me if I'm wrong). Be wise to use the calculators mentioned earlier in the thread, and make sure the auto one was a correct selection to start off with.
bArNsY |
what about the 3.27 ratio?
_________________ FG G6E Turbo |
ToranaGuy |
bArNsY wrote: what about the 3.27 ratio?
My Gregories has the diff ratios listed as: EB Series 2 - 3.27:1 ED - 3.08:1 or 3.27:1 Cheers ToranaGuy
Gaz |
--3.27 diff
EB2+ box : 100km/h = 1942 RPM EA box : 100km/h = 2104 RPM
samftr |
EF 3.08 diff
and EA t5 2200 RPM @ 100.
_________________ 175.7hp 15.5 @ 374,000km
kato |
EF XR8 T5 3.23 diff 2100rpm @100km/h.
_________________ EF XR8 5spd: 302ci /178rwkw |
hannibal |
ToranaGuy wrote: Guys, I'm talking about Top Gear RPM @ 100kms, Sorry if that isn't clear. will it start for set up purposes with the auto ecu?
snap0964 wrote: Couple of things I'm assuming: You've used the same speedo drive gear, and the car runs 15" rims. I suspect the T5 you've fitted is an EA one (despite you saying it's from an ED). Have a read of http://www.fordmods.com/forums/viewtopic.php?t=38250 and check the g/box for the 'roofing nail'. My Eb is running 17's, 235/45's. I used the speedo drive gear that was in the T5. The T5 was from a factory ED 5spd, low kms, even had a relativly new genuine clutch fork & clutch setup. 115k kms on the car. I had a read of the thread you sugested, and went thru some pics of the engine & T5 while i had them outta the car, and i DO HAVE that " roofing nail " near the reverse switch! So it's not an EA box! I was 99% sure it was a ED box, as i 've still got the rest of that damn car in my front yard! I bought a whole ED GLI 5spd from the Auctions ( pickles ) to do the swap. Pic of engine & T5 in my gallery, http://www.fordmods.com/forums/gallery. ... f=9895&m=0 I did the conversion, all parts from the factory 5spd, OMFG what a pain that was, but i love the EB with a 5spd. I have used the manual ECU & manual gearbox wiring loom. No wiring mods there. I take it the speedo drive for the GLI may not suit my GHIA. I've got my auto in the shed atm, was thinking about fitting it & my other I6 into the ed then selling the car. I'll take a look at it's speedo drive & possibly swap them over. I just looked @ the time, damn i gotta get to bed, have to be up in about 5hrs. * EEK * Thanks for the help guys, greatly appreciated. Cheers ToranaGuy
_________________ Just got an old EB, but engine odd, specs match stage 2 of crow cams specs? |
cjh |
I had mine out on the hiway yesterday, EA with T5 and 3.27 diff gears, and 235/60R15 tyres on it. Does 1800rpm @ 100kmh in 5th.
Those tyres are taller than std, as in 205/65R15.
snap0964 |
hannibal wrote: will it start for set up purposes with the auto ecu? If you're referring to an auto/manual change, yes it will, but you need to join the starter relay wires at the inhibitor switch to motor it over.
The engine will idle high (around 1200 rpm), and EF/El's will have the thermo fans roaring. Otherwise the car will drive.
Users browsing this forum: No registered users and 26 guests |
