Krytox |
EF
Manual (5th) 3.23:1 225/50/16's 100km/h 1950 rpm (approx)
Krytox |
Tyre Height Calculator.
http://www.differentials.com/calc.html Engine RPM Calculator. http://www.csgnetwork.com/multirpmcalc.html
samftr |
snap0964 wrote: hannibal wrote: will it start for set up purposes with the auto ecu? If you're referring to an auto/manual change, yes it will, but you need to join the starter relay wires at the inhibitor switch to motor it over.The engine will idle high (around 1200 rpm), and EF/El's will have the thermo fans roaring. Otherwise the car will drive. you can trick the ecu. there are threads on this throughout fordmods and even on fordforums aus... I did it to the ef, but I couldnt stand the rotten idle quality it had.. I tricked the ecu into thinkiing the auto was in neutral and was at operating temperature, but it never ran spot on.
_________________ 175.7hp 15.5 @ 374,000km
ToranaGuy |
I'm not going to even try the Auto ECU in the car, as i don't want to hack the auto wiring loom up to " trick " it to work with the manual, it needs to be used in another car, the wiring & auto ECU.
I've been on a road trip this w/e, went with g/f's bro to pickup a torana in sydney, just got back 2 hrs ago. Have not played with the ford for a couple of days now. Will go thru some cluster wiring, there may be an issue there causing gauges to read incorrectly. Cheers ToranaGuy
_________________ I am the ToranaGuy!|74 Lh Torana Turbo|78 Hz PanelVan|86 Mighty Boy Ute|93 EB2 Ghia,GT Mockup,5spd,LPGI,Full Leather|2 x EB Xr8 5spd's|FS [VIC]: Wrecking - Eb XR8 - Parts available |Build Thread|Ebay Items - Ford Parts| |
TROYMAN |
ive noticed that there are slight differences in rpm with 3.08 diff with the 5 speeds..in other peoples cars ?
mine does 1950 rpm @ 100 kmph with a ea 5 speed 3.08 diff and 235/45/17 |
cjh |
I had my JMM Interceptor hooked up for the first time yesterday arvo, and find out my tacho is out. I had the tacho recalabrated 7yrs ago, so now I know its out. 500 rpm on tacho is in reality is 750 +/- 40.
So, I'll have to work it out now as to what it should be.
FordFairmont |
Posts: 6113 Joined: 8th May 2007 |
95 EF 6cyl Fairmont
factory 3.23:1 diff ratio EA-EB series1 T5 gearbox 2100 rpms @ 100km/h |
needfordspeed |
95 EF Futura
3.9 LSD 17" Wheels with 35 or 45 profile (can't remember exactly) 2450 RPM in fifth
_________________ 1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Resprayed|microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Wade turbo cam|Crow double valve springs|1.3mm MLS headgasket|C4 conversion|Built bottom end|10.6@125MPHi |
jrfttf |
2500rpm! 3:79 gears and 18's!
FordFairmont |
Shiite!!
As tempting as 3.7/3.9 gears are, i couldnt have my motor revving its nuts off at cruising speed. What kinda revs is it doin at 110km/h? |
ToranaGuy |
jrfttf wrote: 2500rpm! 3:79 gears and 18's!
Ouch! That would have to chew thru fuel, but i'm sure it would jump off the line quickly. I've got all my electrics sorted, i'm sitting on 2000rpm for a " real 100kms ", and 1950 for what my speedo is showing as 100kms. Much better. Cheers ToranaGuy
Smokey...Retired! |
MInes about 2350rpm at 100 on a Ef xr6 with 3.45
_________________ Blast from the past..... |
eMpTy |
My EB XR8 sits at just under 2000rpm @ 100. Running a 3.45 and 18's.
_________________ Cheers |
Smokey...Retired! |
THere must be different ratio t5's cos mine is on 18's aswell :s
eMpTy |
Dunno, my tacho may be out due to custom guage faces. Speedo's spot on though, found that out a couple of weeks ago when the hairdryer got pointed at me.
Users browsing this forum: No registered users and 57 guests |
