t5 poping out of reverse (advise)
Page 1 of 1 [ 12 posts ]
 Post subject: t5 poping out of reverse (advise)
Posted: Wed Sep 03, 2008 4:45 pm
Gallery: 9 images
Ride: 02 xls ute 347
SA, Australia
im lookin at buying this ea falcon for $200 its crappy CFI and looks liek a piece of s**t but its 5spd :D
the problem is that the bloke said it pops out of reverse sometimes my question is, is this common can it get worse would it be worth buying it and converting mine to manual
02 series 3 AU marline ute 5speed 347 stroker
Posted: Wed Sep 03, 2008 4:49 pm
Gallery: 25 images
Ride: EB2 Ghia,Mighty Boy,Eb1 Xr8 5spd
I'd buy it for that price, because you could afford to & should do a full rebuild on the box, then you should be right.
ToranaGuy
I am the ToranaGuy!|74 Lh Torana Turbo|78 Hz PanelVan|86 Mighty Boy Ute|93 EB2 Ghia,GT Mockup,5spd,LPGI,Full Leather|2 x EB Xr8 5spd's|FS [VIC]: Wrecking - Eb XR8 - Parts available |Build Thread|Ebay Items - Ford Parts|
Posted: Wed Sep 03, 2008 7:26 pm
Gallery: 10 images
Ride: 96 XH/97 EL
If it drives okay in the forward gears without popping out, then it shouldn't need a big job to fix reverse.
Normally popping out of gear is movement of the shafts, but in this case it may be a weak spring in the reverse detent.
As mentioned, it would be wise to strip the box and inspect, replace substandard parts, check preloads, etc.
Posted: Wed Sep 03, 2008 7:54 pm
Gallery: 20 images
Ride: 03 BA Fairmont
busted engine/gearbox mounts?
Regards,
Punnisher_42
_____________
2003 BA Fairmont - Stock standard
1994 U13 cough Nissan Cough Bluebird
Favorite Quotes:
"Sportwagon = homo-erotic wank-fest." - downingj
Posted: Wed Sep 03, 2008 8:21 pm
Gallery: 10 images
Ride: SF5 Forester
the whole popping out of reverse is fixable...
remove the tail shaft and loosen the gearbox mount slitghly.. and get in the car and undo the four bolts holding the selector in the top of the box and you should see a welll basically looks very similair to a spring and a ball in a grove....
dismantle that bit get a file and sharpen and widen the grove and put back to gether...
we did this to my cousins old EA... that spring and ball help keep the selector held into place.. my fathers EA does this but the forward gears are good... reverse pops out but he has learnt to live with it.... jsut park were reversing isn't required lol
R.I.P Tobias my son.
Posted: Wed Sep 03, 2008 8:56 pm
its only a falcon - i'd just be inclined to force it in there and hold it there as you pull the clutch out...
Posted: Wed Sep 03, 2008 9:32 pm
Gallery: 9 images
SA, Australia
yeah thats what i was thinking i have no problem with just holding it there if its not going to affect any thing else
im nto to sure if it has broken mounts or gear box mounts because i didn't even no the guy he just went to my school and i saw his car had manual in it and i asked him if hes selling it lol and he said yeah for $200
also im not planning on keeping the car im just getting it for the tyres and 5spd conversion
im not to keen on pulling the box apart because i havnt many things before exept pocket bikes lol
but if its as simple as use say it is maybe it wont cost to much to get it fixed up
Posted: Fri Sep 05, 2008 2:10 am
Gallery: 25 images
With the help of either a Gregory's or a Factory Manual, rebuilding the 5spd shouldn't be too hard if you have played with pocket bikes before.
To be honest, if the car is only costing $200, the 5spd could probably use a freshen up just so it doesn't fail on you within a couple days / weeks of fitting it to your car. Nothing worse than fitting something second hand, then have to pull it back out to reco it not so long after. Also, if the clutch isn't looking too crash hot, get the flywheel machined & a new clutch kit when you fit it.
I did that once with an engine for my Mighty Boy, never again.
ToranaGuy
Posted: Fri Sep 05, 2008 11:44 am
Gallery: 9 images
SA, Australia
i know what you mean man
it would suck having to put it in then ripping it out again
i dont have a Gregory's manual
do you know what is involved in rebuilding a t5 and giving it a service
with the 5p conversion can i use the auto tail shaft?
Posted: Fri Sep 05, 2008 10:00 pm
Gallery: 25 images
Tail shaft = YES.
The rebuild, i didn't have to rebuild mine as it was only 115k kms old & shifting like new still. I just put some new seals on it & in it went. But i've rebuilt a 3spd in my torana many years ago, without a manual it wasn't too hard.
A Gregory's is a good investment, it's helped me out heaps with my EB, as previously i'd only worked on old holdens & fords, nothing past a '80 model! lol.
ToranaGuy
Posted: Sun Sep 07, 2008 10:02 pm
Agreed!
Posted: Mon Sep 08, 2008 1:33 am
Gallery: 25 images
Private9 wrote:
Agreed!
But how much damage could you do to the gearbox & shifter by doing this over the long period of time?
ToranaGuy
Users browsing this forum: No registered users and 28 guests
It is currently Fri Mar 29, 2024 11:42 am All times are UTC + 11 hours
