Interceptor |
got a couple of problems with the T5 in my Sprint (245,000km old)
1: 4th and 5th gears whine after 20-30k's at 100km/h, whining doesnt start straight away, but fades in and out untill settling in after the first 20-30km or so, dropping to 80 changes the pitch, and going to 3rd stops the wine at 80, and going up to 4th or 5th after that brings a few moments of peace, but not for long 2: cruising around town (40-60km/h) the box will occasionally slip out of 3rd gear very quietly, and you dont notice anything till you realise you're slowing down, i suspect its worn synchro's, but not 100% sure 3: if i get off the clutch quickly in 1st without holding it in 1st, all i get is a loud thunk and the shifter jumping back to neutral, i suspect this is related to #2
_________________ Banned |
Disco Frank |
As you know the T5 aint the strongest box around
You could try some Redline oil in ther heard it helps a bit or if it was me i would source another T5 and get that rebiult super strong if possible and replce with the worn 1 out of your car
_________________ RIP SCOTT |
Interceptor |
*meh* probably cheaper to replace it with a richmond 5 speed or a T56
xpression |
but then its not an authentic sprint
Interceptor |
xpression wrote: but then its not an authentic sprint ..... and?
IMO its got enough K's on it that i'm not doing any real harm by modding it provided i can put everything back to original if ever i fel the need to..... (as if!)
old_mate |
synchros are gone i'd say. I had a T5 that wouldnt stay in gear at all, it also stripped had some teeth from 1st
_________________ too many rabbits in china |
tickford_6 |
Posts: 6449 Joined: 11th Nov 2004 |
Interceptor wrote: *meh* probably cheaper to replace it with a richmond 5 speed or a T56
so you are saying it's cheaper to put a t56 in there.. a fully built T5 with 18th inch wider gears heavy duty bearing, heavy duty input shaft. rated to 500ft-lb is 2600 pluss shiping from the states. or you can order just the gear set for $1450 pluss shiping pyroas t56 conversion cost him over $8000 and is rated to the same torque |
wild6 |
where in the states can u order those stronger t5's from do u have a website or contact details or anything?
_________________ series3 xr8 5 speed manual, pacemaker extractors, 3' exhaust, lowered cold air intake, k&n filter, interior, 3.9s
tickford_6 |
wild6 wrote: where in the states can u order those stronger t5's from do u have a website or contact details or anything?
http://www.g-forcetransmissions.com/ |
wild6 |
thanx for that mate itll be something ill need to look at in the near future
Interceptor |
tickford_6 wrote: Interceptor wrote: *meh* probably cheaper to replace it with a richmond 5 speed or a T56 so you are saying it's cheaper to put a t56 in there.. a fully built T5 with 18th inch wider gears heavy duty bearing, heavy duty input shaft. rated to 500ft-lb is 2600 pluss shiping from the states. or you can order just the gear set for $1450 pluss shiping pyroas t56 conversion cost him over $8000 and is rated to the same torque any idea how different the internals in a ED Sprint gearbox are to a normal one? i remember reading somewhere that not only are the ratios different, but the bearings, etc are larger
tickford_6 |
if you check out the g-force website, they have a full ratio list for the all the different gear sets, ( straight dog, helical dog, helical syncro)
prydey |
slipping out of 3rd and 1st could be as simple as bolts need tightening where shifter bolts to box. rubber mounted and bolts can come loose so instead of slotting properly into gear its just flexing on the rubber. probably being a bit hopeful but would pay to check anyway although by the sound of it it needs to come out anyway.
_________________ eb v8: low loud and fast. just how a v8 should be. i guess the big question is, is it fast enough... |
Interceptor |
prydey wrote: slipping out of 3rd and 1st could be as simple as bolts need tightening where shifter bolts to box. rubber mounted and bolts can come loose so instead of slotting properly into gear its just flexing on the rubber. probably being a bit hopeful but would pay to check anyway although by the sound of it it needs to come out anyway.
the 2 bolts holding the shifter handle to the box are tight, and the box is positively selecting the gears, just pops out of them for no apparent reason
gros20 |
spoke to my brother inlaw he did his apprenticeship at ford u can get rebuild kit for them easy as. (i hav ethe t5 manual here as well pm if u want it) he also said u cna easyly gte stronger parts for it if need as well. but even if at every 245000km u need a $100 rebuild kit u are doing well
Users browsing this forum: No registered users and 46 guests |
