Oil sender thread
Page 1 of 1 [ 8 posts ]
 Post subject: Oil sender thread
Posted: Mon Mar 28, 2011 6:26 pm
Ride: EL XR6
Ok I know this has been covered a bit but I can't find an exact answer,
One thread said 1/8NPT, then said 1/4NPT, another said 1/4 BSP and 1/8BSP. so much confusion
I'm thinking it's 1/8 NPT. because on a thread this guy brought and oil cooler and it had 1/8 NPT fittings.
It's for my el btw
Also how long do u turbo guys have Ur oil line? On average length.
Just gathering my turbo bits
El XR6 Turbo
Dark Agents,Sunroof, bilstein shocks, 6000k HIDS, 329 mm slotted rotors, twin pot calipers , Climate Control, GarrettT04 turbo,log manifold, crow turbo cam, microtech lt10c, 42lb injectors , 044, surge tank , T56 , rebuilt bottom end , alloy plenum .
Aiming for 300 rwkw
 Post subject: Re: Oil sender thread
Posted: Mon Mar 28, 2011 11:26 pm
It's 1/4 NPT.
Posted: Tue Mar 29, 2011 7:03 pm
Ride: EBII Fairmont 4.0 206rwkw
Bit've thread hi jack. Where is the oil pressure switch on the E series 6?
EBII Fairmont = 206rwkw
EL Fairmont = Daily
Posted: Tue Mar 29, 2011 7:11 pm
Ride: EL XR6
It took my sender to work and measured it etc and it is 1/4 NPT ,
The pressure sender is under the bbm ( inlet manifold) it looks like a black tube and screws into the block.
El XR6 Turbo
Aiming for 300 rwkw
Posted: Tue Mar 29, 2011 11:33 pm
Cool thanks. If thats faulty, would that cause the gauge to play up?
EL Fairmont = Daily
Posted: Wed Mar 30, 2011 6:54 am
Ride: EL XR6
Most certainly , what is Ur gauge doing?
Reading low then high? Keeps moving ?
El XR6 Turbo
Aiming for 300 rwkw
Posted: Wed Mar 30, 2011 12:46 pm
when the motor's running, it sits right on high.
When its off its off like normal.
I just got the heater tap and a hose fitted, and noticed this issue right after. Thinking they might've knocked a wire off maybe??
EL Fairmont = Daily
Posted: Wed Mar 30, 2011 12:53 pm
Ride: EL XR6
It could be high oil pressure, best way to check is take the sender off and fit a gauge on there.
Or check and clean the terminal on the sender
El XR6 Turbo
Aiming for 300 rwkw
Users browsing this forum: No registered users and 37 guests
It is currently Tue May 20, 2025 11:18 pm All times are UTC + 11 hours
