Grinding noise from EF steering
Page 1 of 1 [ 5 posts ]
 Post subject: Grinding noise from EF steering
Posted: Mon Feb 21, 2011 8:56 pm
Ride: EF falcon
hey
lately my car has been making a grinding noise that seems to be coming from the steering rack under the engine. the noise only happens when i'm going slowly, like when i'm in a parking lot or doing a u-turn.
this problem only happened after i swerved to avoid an obstacle and locked brakes at about 60-70 but i didn't hit anything.
if anyone knows what the problem could be and how i could fix it, that would be awesome. i don't really have the money to put it into mechanics, but if that's the only way, i guess it will do.
thanks.
 Post subject: Re: Grinding noise from EF steering
Posted: Tue Feb 22, 2011 7:25 am
Ride: Ford EL Fairmont Ghia
u checked ur power steering fluid mate? if its bone dry that could explain the grinding noise your hearing, and while the car is near stationary is when power steering is working at its hardest, give it a look and c how u go mate
Posted: Tue Mar 01, 2011 4:10 pm
Ride: EF falcon
hey
i checked the fluid and it's pretty much full. i topped it up and the noise is still happening. it doesn't happen every day and some days it's louder than others.
Posted: Tue Mar 01, 2011 6:05 pm
Gallery: 5 images
Ride: 2021 Amarok V6
My BA started doing this recently, i think the pump itself is on the way out.... the bearing is quite loud now :lol: mind you its done well after 307,000km of abuse.
Posted: Sun Mar 13, 2011 3:23 am
Ride: EF falcon
kinda embarrassing but it turns out one of my brake bads was worn down to steel on the outer edge so it was going steel on rotor on the outer edge...that was the grinding noise.
i changed pads and hope that driving around will kinda smooth out the scoring on the rotor.
i know this is a bad idea, but what's the worst that could happen?
It is currently Sat May 17, 2025 6:34 am All times are UTC + 11 hours
