engine temparture
Page 1 of 2 [ 25 posts ] Go to page 1, 2  Next
 Post subject: engine temparture
Posted: Thu Jun 09, 2005 11:33 am
Gallery: 18 images
Ride: EL Falcon GLI
Just looking at the temp display thingo on the dash, its on the high side of normal, is this usual? like its on the normal side but really close to HIGH, so im wondering if thats a bad thing? Its a 97 EL GLI,
and while iv got you's My heater is a bit of the fritz, when i want hot air, it blows out hot air a for a bit, then it turns ICE COLD! well it feels ice cold due to the whether, reasons why? and how do i fix?
cheers fellas
Jason
Buy my car :) cause i just bought a BA XR6 :)
Posted: Thu Jun 09, 2005 12:27 pm
Ride: BA Fairlane Ghia
If its near the N, you got probs, get your radiator proffesionally cleaned,
Posted: Thu Jun 09, 2005 12:32 pm
Gallery: 29 images
Ride: VU SS
Just get a new radiator, not that much more expensive then a proper clean it seems.
EF Fairmont now Sold!
Guides: {DESCRIPTION}|{DESCRIPTION} |{DESCRIPTION}
Posted: Thu Jun 09, 2005 12:33 pm
Ride: Toyota Supra RZ
in my EB i get a strange reading too........
mine sits like N (eb's only having normal written on the dial) and a bit higher if i come up a hill at 160 with the revs up.
I'm guessing its just the dodgy gauge in the cluster.. is there anyway i can check it with a multimeter on the sensor?
Posted: Thu Jun 09, 2005 12:49 pm
Gallery: 18 images
Ride: EL Falcon GLI
A NEW RADIATOR! are you INSANE? that'd cost a bundle! i was hoping for a new radiator hose or check your fluids or oil levels or something! mainly cause i only saw it as i drove to work today, and a few days ago as well, and havent had the time to pop the lid... cmon!!!!!!
Posted: Thu Jun 09, 2005 1:36 pm
Gallery: 29 images
Ride: VU SS
What $150, not that bad...
Posted: Thu Jun 09, 2005 1:40 pm
Gallery: 18 images
Ride: EL Falcon GLI
considering i just got a $205 speeding fine!!! $150 is quite a stab to my hip pocket!!!
Posted: Thu Jun 09, 2005 1:51 pm
Power: 174 rwkw
$150 better than $500 - $1000 when you cook the head from running too hot. if you are handy round cars do it yourself. pull rad out and stick hose in bottom rad outlet for a reverse flush. not as good as a professional job as they have more pressure but it should do enough. also squirt water through the fins to clean all the leaves and stuff that gets stuck between rad and a/c condensor. check thermostat while coolant is drained. also make sure you have plenty of coolant in at all times. i use tectaloy gold which i have never had probs with but each to their own. either way its going to cost you a bit short term but these motors do not like to run hot so well worth it.
Posted: Thu Jun 09, 2005 3:26 pm
Check your thermostat first, it may not be opening up completely.
Is that the type of response you were looking for?:wink:
If the thermostat is ok then go with a new Radiator!
I had a similar problem with my heater, turned out to be the heater tap wasn't fully openning, worth checking.
Posted: Thu Jun 09, 2005 3:46 pm
When you buy a E series, its the first thing you have done, the radiator checked out, should have spent some money on that, instead of other stuff that is not needed, 150 is cheap for a radiator, cheaper than 1000 plus for head gasket, decking, and labour to put it in. Keep driving it like that, and you will be walking for a while, if you cant afford 150 odd.
Posted: Thu Jun 09, 2005 3:53 pm
Gallery: 18 images
Ride: EL Falcon GLI
yeah looks like it'll be happening soon
Posted: Fri Jun 10, 2005 12:58 am
Ride: 1996 EF Fairmont Ghia
My suggestion is the thermostat, mine used to be really low in temp but when my radiator got repaired my mechanic changed the thermostat and said that the person before you that had it put the wrong type in :shock: .
Some people :evil:. Ohwell if they are not too expensive (i dont have a clue how much) i might be worth grabbing a new one and change it over.
Hope this helps.
- 2.5'' mandrel bent exhaust
- Au xr8 air intake snorkel
- Tinted windows
- Two way electric sunroof
Posted: Sat Jun 11, 2005 10:18 am
Ride: 1997 Falcon EL Gli/Sleeper
On EL's & EF's the optimum Engine temp range (Hot or Cold Conditions) is acheived when the Temp needle sits on or around the "A" on the Normal lettering. If the needle starts sitting on the "R" then you got problems. Go to Radiator specialist to get it checked out otherwise if you dont do that and like others have said, start saving up a couple of grand for a new MOTOR
" In life their is never an Obligation just an Opportunity to..Own an awesome 1970 Ford Mach 1 Mustang! "
Posted: Sat Jun 11, 2005 11:57 am
Ride: EL Fairmont Ghia V8 Turbo
Power: 303 rwkw
Check thermos - mine gets up to the R of normal every now and again and its cause the wiring to one of the thermos is a bit dodgy so it cuts in and out, hence why it doesn't cook itself but sits high as one works one doesn't. Check wiring and relay.
EL Fairmont Ghia V8 Turbo 303rwkw
Posted: Sat Jun 11, 2005 10:19 pm
Gallery: 20 images
Ride: 03 BA Fairmont
....and a few days ago as well, and havent had the time to pop the lid... cmon!!!!!!
If mine ever clmbs higher than usual, it's not a question of time, it's a question of where can i pull over and ckeck it out.
Dosen't take much to warp a head or blow a gasket with the i6, so any temperature other than where is normally sits means DANGER!!! and pull over and find out why IMMEDIATELY.
Regards,
Punnisher_42
_____________
2003 BA Fairmont - Stock standard
1994 U13 cough Nissan Cough Bluebird
Favorite Quotes:
"Sportwagon = homo-erotic wank-fest." - downingj
Users browsing this forum: No registered users and 38 guests
It is currently Thu Jul 10, 2025 8:25 pm All times are UTC + 11 hours
