bry40l |
the el has lost spark now that ive brawled and argued with the dizzy lining the oil pump up to slot it in properly, so now can i check the coil so i can rule that out? if i turn the ignition on can i ark the coil lead out or not? i only have a cheapo chinese $2 shop multimeter if this can be used? also how can i check that the tfi is or isnt rooted as i think this is the cause?
thanks edit: i was just reading my useless repair manual and i think it said not to ground the coil
_________________ BF XR6 |
fairlane6970 |
That's the old school way hold with insulated pliers and hold near earth point (block) "sparkies"
bry40l |
will it wreck the coil or not lol i just wanna see if its working, not blow it up if it is working fine lol
Gab1 |
She'll be right mate.
Gab |
bry40l |
oki doki so sparkles are the way to go lol
1tuff |
stick ya tung in the end of the lead and get someone to crank the ignition
_________________ To many project's and not enough $$$ |
Gab1 |
{USERNAME} wrote: stick ya tung in the end of the lead and get someone to crank the ignition ![]() ![]() ![]() ![]() |
bry40l |
{USERNAME} wrote: stick ya tung in the end of the lead and get someone to crank the ignition LOL yeah 1 way of doin it, my dad said "hold that plug lead while i crank the motor so it doesnt get caught on the fanbelt, i was about 10, i got a good shock, then i did it to all my mates for years later who had no mechanical experience at all hahahaahaha
-GAS-MAN- |
{USERNAME} wrote: {USERNAME} wrote: stick ya tung in the end of the lead and get someone to crank the ignition LOL yeah 1 way of doin it, my dad said "hold that plug lead while i crank the motor so it doesnt get caught on the fanbelt, i was about 10, i got a good shock, then i did it to all my mates for years later who had no mechanical experience at all hahahaahaha That is very funny, but the voltages in a cars ignition system are generally lethal. I dont mean for that to sound condescending, i worded that poorly Matt
_________________ it can be fast and cheap,but it wont be reliable |
EL___Fairmont |
{USERNAME} wrote: the el has lost spark now that ive brawled and argued with the dizzy lining the oil pump up to slot it in properly, so now can i check the coil so i can rule that out? if i turn the ignition on can i ark the coil lead out or not? i only have a cheapo chinese $2 shop multimeter if this can be used? also how can i check that the tfi is or isnt rooted as i think this is the cause? thanks edit: i was just reading my useless repair manual and i think it said not to ground the coil Why don't you just use a longer lead No1 or 2 and plug it onto the coil. Put a spark plug on the other end of the lead. Use some 5mm etc insulated cable wit 2 alligator clips on either end. Clip one end to the spark plug thread and the other to the block. If you see a nice blue spark at the plug while starting the car, your coil is GOOD....... cheers...................
_________________ Current ride 2007 |
bry40l |
{USERNAME} wrote: {USERNAME} wrote: the el has lost spark now that ive brawled and argued with the dizzy lining the oil pump up to slot it in properly, so now can i check the coil so i can rule that out? if i turn the ignition on can i ark the coil lead out or not? i only have a cheapo chinese $2 shop multimeter if this can be used? also how can i check that the tfi is or isnt rooted as i think this is the cause? thanks edit: i was just reading my useless repair manual and i think it said not to ground the coil Why don't you just use a longer lead No1 or 2 and plug it onto the coil. Put a spark plug on the other end of the lead. Use some 5mm etc insulated cable wit 2 alligator clips on either end. Clip one end to the spark plug thread and the other to the block. If you see a nice blue spark at the plug while starting the car, your coil is GOOD....... cheers................... oki doke will do, thanks
tickford_6 |
{USERNAME} wrote: That is very funny, but the voltages in a cars ignition system are generally lethal. I dont mean for that to sound condescending, i worded that poorly Matt Voltage doesn't kill you. AMPS is what kiils you. hence you can get zapped by a an MSD 6AL and live, that only on average 60 000 volts. but it's stuff all amps. Get up into the 7 series and above and you need too take some care. {USERNAME} wrote: the el has lost spark now that ive brawled and argued with the dizzy lining the oil pump up to slot it in properly, so now can i check the coil so i can rule that out? if i turn the ignition on can i ark the coil lead out or not? i only have a cheapo chinese $2 shop multimeter if this can be used? also how can i check that the tfi is or isnt rooted as i think this is the cause? thanks edit: i was just reading my useless repair manual and i think it said not to ground the coil Coils are cheap, just by a new one and be done with it. |
bry40l |
yeah i dont have the money to just replace everything otherwise i would, if it aint stuffed i cant replace it, otherwise i would probably would of done the coil, tfi new gasgets on the motor before i dropped it in, but it all seems good no leaks and if the coil works i wont bother to replace it, i have my suspisions its the tfi as its got a crack in it, definatly needs replacing
bry40l |
i have 12 volts getting to the coil via that funny plug that looks like a injector plug when the ignition is switched onto full accesories, when i turn the car over i have no spark coming from the coil through a spark plug lead to a spark plug earthed to a rocker cover bolt, also, what is the red cable coming from the engine loom to the coil? is this like a trigger wire to tell the coil when the cars turning over? it had 0 volts at this little wire while idiot lights were turned on but i have no one to turn the car over by key while i check it for volts turning over..
looks like my coils had it
TROYMAN |
The red wire is 12 v ignition. The other wire is the trigger wire from the tfi.
