maccaslasher |
Hi All
Im a newbie here, looking forward to getting to know a few of you out there. I have just fitted my engine back into my car after having it fully rebuilt. The block was bored 40thou over, and it has a mild crow camshaft, not the one that requires the chip. Only other mods are extractors, 3 and 1/2 inch exhaust and a pod filter. What id like to know is: is there anything else i can do to it to gain noticeable power without going turbo or supercharger. |
efxr6wagon |
Hey, welcome. Lots of good guys (and gals) with heaps of experience - good and bad
![]() As for a few extra horses N/A, here's a few suggestions: - breathing in: larger snorkel (EL GT or SS Inductions), 3" airbox exit (which you prob already have if you are running a pod), larger throttle body (helps top end only) - compression: AU MLS head gasket (if you don't already have it); head shaved - hotter cam - head work: porting, multi-angle valve job, back-cut intake valves - breathing out: sounds like you already have this sorted, but maybe a high-flow cat - under-drive pulley: less power lost to A/C, P/S, alternator and water pump; possibly Davies-Craig electric water pump. - ignition & fuel: AU injectors, projected-tip spark plugs (eg, Autolite 985), J3 chip (you will be running over-rich for sure; a custom pre-programmed chip can make good gains, especially if tuned for high-octane fuel, and will take maximum advantage of your other mods - and is a bargain at $190 from TI Performance) FWIW
_________________ 95 EF XR6 wagon, 17" FTRs, DBA rotors, KYB/Koni, AU bottom end, ported EF head, backcut valves, SS Inductions, Territory intake, 10.2 CR, Auckland 1258 cam, vernier gear, PH4480 headers, no cat, Tickford 2.5", 2800rpm stall, J3 chip |
phongus |
I would say replace the 3.5 inch exhaust for a 2.5 inch. Hi flow cat isn't necessary, but if you want that extra odd kw or so, why not.
Intake can be upgraded using larger snorkel and implementing a XR6 turbo air box into the mix. From air box to throttle body you can use a Territory or BA intake for a stock look or just get a custom 3" piping made up to suit. A larger TB or smoothed out internals of the TB might help some gain...but intake wise, you won't get much gain out of it. Only other things would be bigger cam, head work and tune.
maccaslasher |
Thanks guys. Some good ideas there. I'll try them out and let you know how it goes.
Users browsing this forum: Google Adsense [Bot] and 88 guests |
