Ultra low or superlow kingsprings??????
Page 1 of 2 [ 27 posts ] Go to page 1, 2  Next
 Post subject: Ultra low or superlow kingsprings??????
Posted: Thu Aug 25, 2011 6:34 pm
Ride: nl fairlane
Hi all
Ive got a 98 nl fairlane 6cyl and im goinig to lower it but before i did i wanted to get some suggestions off some ppl who might have lowerd there car.
I was looking at a set of ultra low kingsprings and monroe shocks for which they say will lower the car 65-70mm, does anyone know if this is true???? If so would it be at an illegal height?? :?
Or should i stick with superlow springs and shocks?? for a better ride??
Thanks guys :D
 Post subject: Re: Ultra low or superlow kingsprings??????
Posted: Thu Aug 25, 2011 6:36 pm
Ride: BF XR6,
ultra lows would make car parks with speed humps and drive ways an a**hole to drive into
BF XR6
Posted: Thu Aug 25, 2011 7:27 pm
Ride: AU fairmont ghia
superlows, being a LWB fairlane it will be a real prick to drive being on ultralows
AU FAIRMONT GHIA: 5.0 Dealer ordered SVO mods ( seeking clarification ATM), tickford suspension.
Posted: Fri Aug 26, 2011 8:42 pm
Ride: 96 EF 5 Spd
On my EF mont i have superlow fronts and ultra low rears
the ride i dont mind it and i dont have too much trouble with driveways and speedhumps
its also just over legal height limit as i was pulled over and cops tried getting me for too low but it passed the rta inspection crap as the lowest part of the car was above 100mm
pic of the car below so you can picture i dont have any side views atm
Posted: Fri Aug 26, 2011 8:53 pm
Ride: VE SS ute, EL Typhoon mock
+1
Also riding on ultras rear and supers front (on gli though) and never had any problems with roadworthy cert or police... And rarely scraped anywhere
YES.40L
El Gli/Fairmont/Typhoon-twinlights, king springs, paccies, dark agents
Posted: Fri Aug 26, 2011 10:25 pm
+1
Dont know what i was thinking.. I have lows and super lows... My bad
YES.40L
Posted: Fri Aug 26, 2011 10:32 pm
Gallery: 9 images
Ride: NF Fairlane Ghia
in my NF ive got superlows in the front and falcon normal lows (when in a fairlane makes a inbetween superlow and low due to fairlanes are heavier in the rear) and it works pretty well i defiantly wouldn't go lower than superlow i can hardly get jacks under my NF and have to take all driveways on a angles
i use to have falcon superlows all round but it was way to low the rear would always scrape on everything if your going to go superlow in the NL mate get proper fairlane rear superlows
NF Fairlane Ghia, Brand New Leather Interior, Wallnut All Through, 800W RMS JL Audio Sound System, Lowered King Springs And Monroe GT Shocks, Custom BA/GT Air Intake, Holley Highflow, Simmons B45's, Going To Be Supercharged At 9-12psi With Stage 4 Head And Cam With Pacemakers And 3" Exhaust
Posted: Fri Aug 26, 2011 11:56 pm
Ride: falcon
Hey,
I have had both superlow and ultralows in my DF (5.0 V8 with LPG tank in the back) LTD running 19x9.5 front, 19x10.5 rear and with Koni Reds shock absorbers.
Practicality wise, it really depends on the type of roads you drive on and whether the roads will permit the ultralows i.e. how steep are your driveways. Another factor is how strict the cops are around the area.
Emotionally, it depends on far it takes before you are satisfied with a cars looks. With the ulralows, your cars lowest point is the flanges on the exhaust, generally it is the flange at the middle of the car. So eventually, your exhaust will need to be raised as close to the body as possible. The front tires will scrub on the guards and maybe the rears depending on how wide and the offset of the wheels. So you will have to roll the lips of the guards and maybe even use a hammer to more clearance.
You get use to driving with ultralows and how to take some of the driveways and avoiding certain speedhumps. On some extreme roads, you will bottom out on the K frame when driving too fast but at most normal speeds it wont happen.
I didn't get hassled by the cops on my ride height.
doing it in reverse with a fwd is like being fuked by a fat man and saying "well he has tits so i'm not gay"
Posted: Sat Aug 27, 2011 12:21 am
Ride: FG Ute, ED XR8 Sprint, GPZ900R
As guide this is my old NF V8 Fairlane with 6cyl ultras all round and gas tank in boot, looked sweet, hated speed humps
The Past: EF Fairmont, EL Fairmont 5.0, HR Special, NF Fairlane 5.0, GSX 250-F, BA II XR8, VS3 Ute, VS2 L67 Calais
The Present: FG Egas Ute, ED XR8 Sprint, GPZ 900R
Posted: Sun Aug 28, 2011 7:32 am
Ride: falcon
here is my contribution of when I was running 17" rims
Posted: Sun Aug 28, 2011 3:21 pm
Ride: nl fairlane
Hey guys,
Thanks for all your posts helped me out alot :)
I reckon ill go superlows with monroe shocks all round, i can get a compleate set for $640 with postage :D I'll be riding on 16 inch dl ltd rims so hopefully it will sit nice hopefully lol will superlows lower it to 50mm or will it aprox be around that height? :? That was the reason i was gona go with ultras in case supers wernt gona be bang on 50mm.
Will i need camber kits if going superlows?? :?
Thanks guys your help is much appreciated
lowlane98
Posted: Sun Aug 28, 2011 5:39 pm
What is the lowest legal height? With my kit I've for about 140mm clearance at the front and 130mm at the back...
YES.40L
Posted: Sun Aug 28, 2011 10:20 pm
Ride: 04 BA Mk2 Xr6
You should be able to fit something that is 100mm under it. 100mm clearance is legal height.
Posted: Sun Aug 28, 2011 10:25 pm
Ride: 1993 EB XR8
Get your low on.
Falcon Superlows in the front, Koni's on the middle spring seat setting, Falcon Ultra low rear with 25mm of spring spacers. Car sits dead level, sills at 110mm front and rear. Cat is substantially lower.
Posted: Sun Aug 28, 2011 10:27 pm
Ride: 04 BA Mk2 Xr6
Not sure if it's different laws in different states, but i know in the area im in, the cops or law or who ever does it, measures from the lowest point of the car. So in pretty much every case, the cat needs to be 100mm clearance.
It is currently Mon May 19, 2025 6:09 am All times are UTC + 11 hours
