XH6 |
Gday iv got an EF motor in the XH i started to put the inllet manifold back on n the Air con compressor is in the way, sum1 suggested to take the bracket off the old XH motor bolt it on to the EF motor and it should be right.? my problem is i cant get it to sit right, i cant get any holes to line up on the bracket and the block theres 6 bolts holes on the bracket
TROYMAN |
the engine blocks are the same, just mount it the same as it was on the xh engine..
you will also need to use the belt tensioner from the xh aswell... |
Users browsing this forum: No registered users and 74 guests |
