Anyone done a manual conversion in a ef fairmont before??
Page 1 of 1 [ 15 posts ]
 Post subject: Anyone done a manual conversion in a ef fairmont before??
Posted: Thu Feb 23, 2012 11:12 pm
hey..
just wondering if anyone has done a auto to manual conversion in a EF FAIRMONT before..??
If so what did you do about ecu??
will manual ecu work with fairmont bcm??
or any other known problems?
 Post subject: Re: Anyone done a manual conversion in a ef fairmont before??
Posted: Thu Feb 23, 2012 11:25 pm
NSW Cruise Moderator
Gallery: 12 images
Ride: TE50
been done thousands of times, BUT, you have 3 options.
    1.So a search for the resistor trick, it will be in resources
    2.You can use an EF manual ECU, has to be EF though
    3.get a J3 with a manual tune on it
Any of these will be suitable for what you are doing.
I have a car.
Posted: Fri Feb 24, 2012 12:34 am
Power: 144 rwkw
Search is your friend or have a look in the Technical Documents forum...there is a thread in there with a pdf file to show you all that you need. I can't be a*** looking for it sorry.
phongus = Post whore 2006
Posted: Fri Feb 24, 2012 10:21 am
Ride: FG MkII Xr6t Ute
Get a j3 chip. I think it is $110 with a stock tune on it and you plug it in and just forget about the auto loom. So simple and if you ever want to go back to auto means you aren't stuck with a cut up loom.
Cramping in the hand from having it on your Wang for an excessive period of time is a definate con.
Seriously do people google "f**k up modifications for Fords owned by Jews" and get linked straight to this site nowadays?
AU,factory fitted tickford kit/IRS, t5,Sports ryder/KYB: gone.
Posted: Fri Feb 24, 2012 10:35 am
Gallery: 5 images
Ride: EL XR6
...if you ever want to go back to auto...
Sorry, what?
LOW, LOUD AND LUMPY
Posted: Fri Feb 24, 2012 11:21 am
Sorry, what?
If you ever want to go back to auto you can plug the auto loom back in and pull the j3 with the manual tune out...
Example 1: I stick a turbo on my car and blow my t5 to pieces and don't have enough money to get a tko or t56.
Example 2: I tow s**t all the time and didn't realise my clutch would wear out so much.
Example 3: I drive in f**k traffic every day and am sick of having a hercules style left leg from my heavy cable clutch.
Example 4: I want to be able to fingerbang my gf while driving, rather than shifting gears.
The other reason you don't wanna cut up your loom is because it looks bad if you are trying to sell your car. Not sure what your car looks like and granted falcons aren't worth a lot, but if I see some tight a** has done the resistor trick I figure he has been a tight a** with the rest of the car.
Posted: Fri Feb 24, 2012 11:38 am
Gallery: 5 images
Ride: EL XR6
I resistor tricked my auto ecu and i run a J3.
What if the J3 has an issue and you need to drive somewhere?
Car isnt going to be too happy with the auto ecu.
LOW, LOUD AND LUMPY
Posted: Fri Feb 24, 2012 11:47 am
Gallery: 5 images
Ride: DENTED UP OLD AUT WAGON
Posted: Fri Feb 24, 2012 11:51 am
Gallery: 5 images
Posted: Fri Feb 24, 2012 11:54 am
Gallery: 5 images
Sorry, what?
hahahaha +1
Oh right. Fair call(s). Other than fingerbanging. Just let her drive....
Sorry, what?
Nek minute...
Nah. This shows someone has spent time and effort researching and knows a bit about their car. Would you buy a fairly factory car from a guy who didn't know much, or similar from a guy who at least knew enough to do a manual swap himself?
I'd by the manual swap at home car... Same reason I was never shy to buy ex-race vehicles (back in the day when I had more than six cents in my bank account....)
If someone shows aptitude for working on the vehicle, chances are that problems have been fixed as they have become apparent.... And maybe you'll find some good s**t later, like after market parts that are worth while hanging onto....
Posted: Fri Feb 24, 2012 12:22 pm
Each to their own - I would never use it personally because it is cutting corners, so I wouldn't buy a car off someone who has. Personal belief that where there is a better alternative use it.
I only buy factory cars from those who look after them.
Anyway this doesn't really relate to the OP's question. Back on topic...
Posted: Fri Feb 24, 2012 12:28 pm
What happens if your soldering fails/otherwise shorts? What happens if the ecu s**t itself?
J3's generally don't just s**t themselves, I think both of those previous two points are more likely to occur first...
If you're that worried get a Manual ECU - then you only have to worry about the ECU dying :wink:
I got lucky and was able to swap the manual ecu I got with my conversion for the correct one.
Posted: Fri Feb 24, 2012 4:44 pm
Ride: ef falcon, el fairmont ghia
i got the manual ecu, but yea i would go j3, prob around same price as an over priced ecu anyway.
Posted: Fri Feb 24, 2012 7:30 pm
yeah ive got manual ecu..
ive got all looms for manual g./box plugged in but when turn key to start it wont start
and the kilometres wont show up? like the odometer.. and when i turn it back off you can hear the fuel pump still going.. lol...
i tried a remanufactured new ecu from melbourne.. still does the same thing...
what else culd be going wrong?
Posted: Fri Feb 24, 2012 9:32 pm
FIXED IT GUYSSS :D
was the starter relay. had to earth out pin 86
thanks all
It is currently Sun May 18, 2025 5:36 am All times are UTC + 11 hours
