Loud Bang ! Now what?
 Post subject: Loud Bang ! Now what?
Posted: Mon Jul 13, 2009 1:53 pm
Ride: Ford EB II Falcon
I was driving my EB II in the water today and there were alot of puddles and as i entered my street the car began to struggle so i put my foot down a bit more then "BANG" under the bonnet white smoke/ or steam was coming out so i shut the car off (as it didnt die with the bang) i had a look and couldn't see anything serious.
Started the car back up and since it was on my street i drove 20km/h to my house and it seemed fine !
What does it mean ? Did i blow something and can i still drive it ?
OLD CAR: EB II Falcon, Everglade Green, 250thous (Rough Guess), Wildcat Extractors, 2.5 Exhaust with Muffler + Hot Dog, 18 Inch Rodney Jane Mags, XH Snorkel, EA MPEFI Tubing !
NEW CAR: 1996 TE Magna...Mods Soon To Come
 Post subject: Re: Loud Bang ! Now what?
Posted: Mon Jul 13, 2009 2:00 pm
Ride: BAxr6 mkII, BA xr6, EA Spac
how has the oil preasure been lately?
did you hear any rattle in the engine bay?
When you got home did u turn it on and pop the hood and listen if it was idling right?
iu have a guy at work with an ef have his sump didnt severly form previous owner and had somethign blow in his car. cant remember exact details but i see himm on wednesday.
long story short he needed a new engine!
but im not sure about your problem
Homer- Everytime i try to learn somethign new it pushes out old information!
Like that time i learnt how to taste wine and forgot how to drive.
Marge- You didn't forget how to drive you where drunk!
Homer- And How!
Successful Trades: Private9
Posted: Mon Jul 13, 2009 2:03 pm
Ok i think the engine back fired because the two clips i had left on the air filter housing one was bent and the other one was near the radiator and where the snorkel mouth bolts down one of the locations snapped and has been separated from the mouth !
Posted: Mon Jul 13, 2009 2:04 pm
Ride: AU XR8
if you were driving through alot of water ??
i would say your dizzy or coil got wet which caused the car to struggle and when you put your foot down it backfired through the intake..(which explans the smoke)
when you went back the dizzy was probably dry and the car should have gone back to normal...
Posted: Mon Jul 13, 2009 2:13 pm
Yes i was also thinking that it was the dizzy ! I have to go out soon it should be good to drive right
Posted: Mon Jul 13, 2009 2:15 pm
i was initialy thnkin backfire but the smoke sounded like what the mate atw ork said so i thought i would enquire more.
if its idilng and running fine and just backfire it should be fine
Homer- And How!
Posted: Mon Jul 13, 2009 2:18 pm
Ok well i will take it out soon and hope for the best and get back to you guys
Thanks !
Posted: Mon Jul 13, 2009 2:37 pm
Power: 139 rwkw
Is it on LPG? Sounds like an LPG backfire to me.
Posted: Mon Jul 13, 2009 2:50 pm
Dual fuel but yes i was on gas at the time !
Posted: Mon Jul 13, 2009 3:19 pm
Power: 139 rwkw
Definately a gas backfire then.
Check that your plugs and leads are in really good condition. This helps stop the backfires.
You can get a set of spring clips off ebay to replacethe standard air box clips for about $22.
The idea is they give when you get a backfire so the airbox doesnt blow apart.
Ride: EL XR6
It shouldnt have done any permanent damage, especially if the car now seems fine to drive.
Might want to check all your intake tubing, the pcv valve on top of the rocker cover and the map sensor hose to make sure they havent split.
EL XR6 Manual
Tickford Kit, 18" ANZ's, Kings SL/SSL & Sachs.
Posted: Mon Jul 13, 2009 5:22 pm
Ride: 2001 au2 sr wagon
or in the short term you can but an ockie strap across the top the airbox's had that on my old EB worked well :)
Posted: Mon Jul 13, 2009 5:29 pm
car seems fine now ! thanks for your help guys!
Posted: Mon Jul 13, 2009 8:17 pm
Ride: BF F6 Tornado - #0077
I'd say a bigish backfire due to water arcing across leads or something. the two tricks cabbies use are either an occy strap over the box or get a hole saw and a rubber gromit from clark rubber.
Might still be worth just checking over the coil and dizzy and TFI just to make sure they're not on the way out :wink:
** For Sale ** {DESCRIPTION}
F6 Tornado 2006 {DESCRIPTION}
No?
Then f**k off
Posted: Sat May 26, 2012 10:26 pm
Ride: Ford EB Falcon Wagon
With Gas powered check you have a steel PCV valve. The early engines had a plastic one that cracks and drops the contents into your valve gear then jams your cam shaft and destroys your engine.... Very expensive. Happened to my XG Ute
Driven heaps of Coons still never owned one.
Driving the new Ford Ranger now
EB for the wife and Kids.
It is currently Tue May 20, 2025 12:20 am All times are UTC + 11 hours
