Flushing EL Ghia cooling system with climate control.
Page 1 of 1 [ 12 posts ]
 Post subject: Flushing EL Ghia cooling system with climate control.
Posted: Sun Oct 07, 2012 12:07 am
Gallery: 14 images
Ride: EF XR8
Not sure on how to open the heater with the computer controlled climate gizmo that the EL Ghias have.
For example, when you'd just turn the dial on a base model all the way to 'red'... how do I convert that to the climate control on the Ghia?
Also, would I need to bleed the system, or would it do it by itself?
Cheers,
Russ.
Blue blooded.
 Post subject: Re: Flushing EL Ghia cooling system with climate control.
Posted: Sun Oct 07, 2012 8:15 am
Ride: EF Fairmont
Set the Temperature as this as possible and turn the heater on demist. No you will not need to do any special bleeding as the system wil self bleed.
Posted: Sun Oct 07, 2012 9:12 am
Gallery: 14 images
Ride: EF XR8
So whack it on 30 degrees, and press the demister button?
Then Ill just whack the hose down the guts of the thermostat housing and let it flush
Blue blooded.
Posted: Sun Oct 07, 2012 11:53 am
its best to remove the climate control module from the dash, and fill it with fresh coolant.
use a funnel and pour into the front vent at the bottom
Posted: Sun Oct 07, 2012 12:08 pm
Gallery: 14 images
Ride: EF XR8
How do you get it out :S
And when you flush it out, do you have to put something over the terminals/contacts?
I've never done it before....
Cheers,
Russ.
Blue blooded.
Posted: Sun Oct 07, 2012 12:48 pm
Gallery: 16 images
Ride: ford ef2 xr6
Just drain and flush coolant as per usual,make sure engine is cool when you do it.To re
fill,set climate control to 32 degrees,refill cooling system to min/add mark on header tank,replace cap to first click only.Start and run engine at 2000rpm for 10 minutes.Stop engine and top up coolant to full/max mark on header tank.This procedure taken from factory workshop manual.
Posted: Sun Oct 07, 2012 1:21 pm
Gallery: 14 images
Ride: EF XR8
Thanks for that, Ill be doing it tomorrow.
Blue blooded.
Posted: Sun Oct 07, 2012 3:35 pm
Power: 144 rwkw
phongus = Post whore 2006
Posted: Sun Oct 07, 2012 3:41 pm
Gallery: 14 images
Ride: EF XR8
It's a different method, thats for sure!
Blue blooded.
Posted: Sun Oct 07, 2012 5:05 pm
Ride: ED V8
Just pull the vacumn hose off the heater tap. Default for the tap is open......
Drain, flush, refill with coolant.
When finished, put the vac line back on the heater tap.
ED XR8 Spri-mitatio-nt
Posted: Sun Oct 07, 2012 6:41 pm
Power: 144 rwkw
Posted: Sun Oct 07, 2012 10:32 pm
Gallery: 14 images
Ride: EF XR8
Blue blooded.
Users browsing this forum: Google [Bot] and 0 guests
It is currently Sun May 18, 2025 9:48 am All times are UTC + 11 hours
