3000km service and oil change?
 Post subject: 3000km service and oil change?
Posted: Sun Dec 02, 2012 3:56 pm
Ride: 2012 Ford XR6 Limited
Hey everyone just looking for some thoughts/opinions about changing the oil at the 3000km service even though ford recommend it to be changed at 15,000km. I have had a few mixed opinions with friends and the boys at work but now I'm wondering what the people on the forums think.
 Post subject: Re: 3000km service and oil change?
Posted: Sun Dec 02, 2012 3:59 pm
Ride: ef falcon futura
Power: 154 rwkw
i usually do mine at 5000ks, but i might be shortening it now seeing as tho my oil is black now. (coming up to 3500ks)
ef futura, pacemakers, 2.5inch catback, k&n panel filter and 3.45 lsd. extractors/cat, ticky head, custom cam grind, t5. now onto cosmetics.
Posted: Sun Dec 02, 2012 4:24 pm
My little rule is..
I do my EB every 5000. BA every 7500. Transmission every 30000 there abouts.
Seems to work for me. :wink:
Posted: Sun Dec 02, 2012 10:07 pm
every 15000km is for "normal conditions" read the hand book and learn what "normal conditions" are. You'll find most people don't fit the catagory of driving conditions.
Personally If the hand book says 15000km intervals, I'd be doing it at 7500km unless you are willing to invest in used oil analysis to prove the oil is good for 15000km. But the cost of that would be right up there with an extra oil change.
Unless you plan on only keeping the car for a few years, then just string the services out as far as you can.
Posted: Sun Dec 02, 2012 10:18 pm
Power: 139 rwkw
Servicing is cheap insurance.
All our cars get done every 5000km.
Posted: Mon Dec 03, 2012 10:18 am
Ride: 93 ED sedan
Power: 161 rwkw
One thing is for sure....Oil is cheaper than replacing engines....or fixing oil leaks.
I do mine every 5,000km or 6 months.....the engines stay clean at that....so far.
http://youtu.be/jJTh9F3Vgg0
Posted: Mon Dec 03, 2012 10:52 am
Dont forget to many oil changes can strip your sump bolt hif hif
but ehh every 5k- 7500km is fine
just remember spoon sport has told people engine's have a filter + it is pressurized
now a manual gear box should be changed at 5K km the same time as the oil as the oil is just floating around in there
Vtec club makes sense to me but does it make sense to us
I will admit though i have changed the oil every tank of fuel when i have bought AUs
my EA which got oil changed every 10K km i did the same every tank of fuel for the first 4 tanks
Posted: Mon Dec 03, 2012 3:44 pm
Ride: FG 50th Anni G6E Turbo
I had my FG's oil changed at 3000km service... then i have changed every 7500 since. I also switched from the mineral oil to synthetic oil at the second oil change. Mine is a Turbo though.
Posted: Mon Dec 03, 2012 3:59 pm
your thinking backwards mate.
shouldnt you be changing at 15,000 intervals unless a used oil analysis proves otherwise?
changing the oil every 3,000, or every 30,000.......... betcha after 100,000km both engines would behave exactly the same.
It would be better piece of mind replacing all the sensors, ignition system, and fuel system at regular intervals....... you know, the things that actually play up over time !! :lol:
Posted: Mon Dec 03, 2012 4:32 pm
Ride: AUII XR6 Uterus
how do you stand with 'refreshing oil' yourself under warranty conditions though? or would it have to go through certified service everytime even though not due?
Posted: Mon Dec 03, 2012 9:54 pm
NO, You change sooner because you can't prove the oil is good without testing it. IF the testing shows the oil is still good, you leave it in and test again. testing every 2500km will show you a lot about your engine and your driving habits. Over time you will see the trends in oil contamination and engine wear that will give you the ability to better judge your needed oil change intervals. Continued testing will show up potential mechanical or filtration problems long before they become a major issue.
I proved that Fuchs GT1 0W20 was good for 15000km in my old LPG fueled AU. the testing also showed that K&N filters are NOT good filters, It also showed later that a leak had developed in the intake after filter (which had been changed back to a motorcraft paper filter). it also showed that the thin 0W20 had very good wear protection and disproved the s**t story of thick oil protects better. It also showed the effects of the s**t K&N filter by finding high levels of aluminum in the oil, piston skirt wear induced by the dust getting through the K&N filter. This was proven by changing to a motorcraft paper filter, after which the high dust and aluminum levels did not show.
Would I trust the same oil to do the same job in the BA we bought, Not with out testing.
Although this time I will be testing a different Fuchs oil that is specifically designed for long drain intervals.
Incorrect. i've seen engines with under 100 000km that have oil sludge related problems that would not be there if the oil was at shorter intervals. The repairs cost more then the people saved by stretching out the services. :wink:
All the cars I've seen with those problems have had some form of VCT, these include a BA falcon, a Honda CRV and a Toyota corolla.
Servicing the fuel system and ignition systems are part of the scheduled services anyway. :roll:
Don't tell me you're one of those d***head that thinks a 'service' is just an oil change.
Posted: Mon Dec 03, 2012 11:39 pm
Injectors , coil packs , 02 sensors, leads , temp sensors , TPS sensors are a "basic service" item arnt they tickford_6 ?
i know i change injectors , and 02 sensors every 30-50K km , and coils also etc
Posted: Tue Dec 04, 2012 7:31 am
You'd be surprised how many people think the only thing you ever need to change is oil and a filter.
They much prefer to wait until the other items become a problem before they ask you to fix as cheap as possible (as apposed them wanting it fixed properly)
Posted: Tue Dec 04, 2012 7:57 am
Ride: 5 speed XG ute
I do my XG every 10000 clicks, but i change ALL oils (diff, trans etc) ALL filters, spark plugs and leads etc etc. Check everything over. As for the sensors i never have changed them in 230000 kilometers. Why change them when they work brilliant anyway. Still get great fuel economy, engine is smooth and plenty of grunt so cant be to much wrong lol.
Yep, I don't know what to write here...
Posted: Tue Dec 04, 2012 11:03 am
Ride: 93 ED sedan
Power: 161 rwkw
OK.....other things I do...service wise....
I change the brake fluid every year ( rego time ), lube the door hinges and latches, boot lid hinges, bonnet hinges and latch every oil change,
Lube antenna every 2nd oil change, and key barrels,
If grease nipples are fitted, they get a couple of shots every oil change,
check lights, replace bulbs as necessary,
change g'box & diff oil every 2 years or 15,000 km,
change coolant every 2 years,
spark plugs as necessary....they get looked at regularly...except for the wifes Magna....damn intake covers the rear 3..... :x
Anyway....haven't really had many probs.....just the dizzy's give up at about 12 months.....but then I get them for $99.
The still work.....just they start making a screaming noise....the bush in them isn't real good stuff, me thinks.
I have pics.
Users browsing this forum: Google Adsense [Bot] and 40 guests
cron
It is currently Tue May 20, 2025 1:28 pm All times are UTC + 11 hours
