Timing chain rattle
Page 1 of 1 [ 7 posts ]
 Post subject: Timing chain rattle
Posted: Sat Dec 15, 2012 2:11 pm
Ride: EL XR-6
hey just wondering what are causes of timing chain rattle on start up most of the time and sometime lifter noise? the oil is always full and it the car is always service as usual. could it be faulty tensioner or something else?
 Post subject: Re: Timing chain rattle
Posted: Sun Dec 16, 2012 8:43 pm
Ride: 5 speed XG ute
Could be faulty tensioner, if its not a faulty tensioner, then If it only rattles on start up could mean that the chain has actually stretched... The lifter noise is probably caused by this as well, if the chain has stretched and hasn't got tension then the valves move at the wrong time. I'd say try another tensioner first...
Yep, I don't know what to write here...
Posted: Mon Dec 17, 2012 7:29 pm
Ride: EL XR-6
okay ill give that ago
Posted: Tue Dec 18, 2012 10:06 am
Power: 144 rwkw
Could be broken tensioner or a broken chain guide causing the issues. A stretched chain is usually rare...well I hardly hear about that kind of issue. I'd check for any broken chain guides and check the tensioner. Pull the tensioner out, give it a clean, replace the o-rings and hopefully all will be okay.
phongus = Post whore 2006
Posted: Fri Dec 28, 2012 10:28 pm
Ride: ED Fairmont Ghia
Only use a ryco anti drain back filter, cheap repco ones cause this, happened in my old ef
ED Fairmont, Ghia mock DOHC-T 11.6 @ 118 Trying to get back to the 1/4!
Posted: Fri Dec 28, 2012 10:29 pm
Posted: Sat Dec 29, 2012 10:20 pm
Ride: S1 eb 5speed
Broken guide or if the heads been taken down to min then you can get chain rattle
Users browsing this forum: Google Adsense [Bot] and 46 guests
It is currently Sat May 17, 2025 5:17 pm All times are UTC + 11 hours
