EF_wanabe |
Hey there
Today i was at the wreckers and i was not served by the pretty young blonde a bit disappointing so there i was served by a old man i think me being high as f**k on opiates ( prescription) and talking about her beauty has made her scared of me from the past but i have received a mad discount from her once for a stainless steel cat back after telling her shes beautiful in thesaurus spec words that many people wont understand that hot rack and small little a$$ mmmmm nom nom little pretty thing i would do things to her i wouldn't do to a farm animal i saw a XH/XG ute it was boiling hot i looked for intake and i found it on the ground so i picked it up and $10 later i had it {DESCRIPTION} Uploaded with {DESCRIPTION} {DESCRIPTION} Uploaded with {DESCRIPTION} Now it is way to hot out side its 44C atm and will be for the rest of next week i am scared this may be a XG intake and may not fit please someone tell me and reassure me its a XH one as i believe it may be ? I have found numerous how to guides to fit it and it seems very straight forward i just hope my stock EA fan shroud does not get in the way in conclusion will this fit my EA ? Thank you |
TROYMAN |
yes!!!!!!!!!
evxr6 |
As long as it's MPEFI
EF_wanabe |
{USERNAME} wrote: yes!!!!!!!!! Thanks only reason why i asked is cause i have got the worst luck with cars e.g like my fuel pump problem paid to get it fixed well grandma did and the mechanic did not change the piece of hose in the tank which was all cracked so 2 weeks later it was stuffed again |
5h4dy |
Lucky bugger, I've been looking for one of those for my EB
EF_wanabe |
{USERNAME} wrote: Lucky bugger, I've been looking for one of those for my EB Whats one of those worth down in Waikato ? |
5h4dy |
{USERNAME} wrote: {USERNAME} wrote: Lucky bugger, I've been looking for one of those for my EB Whats one of those worth down in Waikato ? No idea, haven't been able to find one ![]() If I could find one at the local wreckers it would only be about 4 bucks |
EF_wanabe |
{USERNAME} wrote: {USERNAME} wrote: {USERNAME} wrote: Lucky bugger, I've been looking for one of those for my EB Whats one of those worth down in Waikato ? No idea, haven't been able to find one ![]() If I could find one at the local wreckers it would only be about 4 bucks The time will come before you know it. When you least expect it you will see one |
TROYMAN |
there hard to come by now days as they are no longer available from ford and xh is exactly as common as the ea-el.....
i did sell a real good one on ebay a year or so ago and got $60 for it... |
EF_wanabe |
{USERNAME} wrote: there hard to come by now days as they are no longer available from ford and xh is exactly as common as the ea-el..... i did sell a real good one on ebay a year or so ago and got $60 for it... Dam So its a MUST to cut the fan shrouding ? |
TROYMAN |
yep, just the top section where the intake runs
EF_wanabe |
{USERNAME} wrote: yep, just the top section where the intake runs Ok , this is going to suck if i ever want to revert back to the original for some un for seen reason |
evxr6 |
{USERNAME} wrote: {USERNAME} wrote: yep, just the top section where the intake runs Ok , this is going to suck if i ever want to revert back to the original for some un for seen reason Just get another fan shroud. |
ToranaGuy |
You won't want to, and if you have to, there are fan shrouds available at the wreckers. Hell, just go convert to EF thermo fans, then you won't need to change the intake back lol.
Cheers ToranaGuy
EF_wanabe |
{USERNAME} wrote: You won't want to, and if you have to, there are fan shrouds available at the wreckers. Hell, just go convert to EF thermo fans, then you won't need to change the intake back lol. Cheers ToranaGuy Troy has convinced me to go thermos but i have got a near new clutch fan im not going to waste that i will wait it out but will be using a EL ECU so it saves me $40 to buy a thermo switch and get a J3 for a nice tune So is it just me or do these air conditioners suck in the E series? i notice in my EA when it was freshly re gassed it would be cold sure but the car had to be moving for it to work at all it is as if the clutch fan wouldn't keep up to cool the condenser etc clutch fan was worn so i put a new one in and then took the radiator out and there was like cat fur all in front of it haven't driven since due to i did all this work to EA since after my injuries but i did idle it and the air cond seemed to suck but maybe in 9 months the gas may have "escaped" |
Users browsing this forum: Google [Bot] and 70 guests |
