How to simply clean you're throttle body.
Page 1 of 2 [ 30 posts ] Go to page 1, 2  Next
 Post subject: How to simply clean you're throttle body.
Posted: Tue Apr 19, 2011 8:26 pm
Ride: 92 EB s
First, buy a can of threebond "super engine conditioner".
Second, follow instructions.
I have had a couple troubles with dirty throttlebodys causing bad idle, I have tried tomcat throttlebody/carby cleaner, direct injection 3 intake cleaner, a sonax intake cleaner, ect.
This s**t takes the cake by far.
You could hear the change in the engine whilst doing the first rev and I and you could really hear the differance whilst the plumes of white smoke fill the street,
Buy some!
 Post subject: Re: How to simply clean you're throttle body.
Posted: Wed Apr 20, 2011 1:43 am
Ride: BA XR6
kinda hoping that the white smoke was rubber not car fumes :lol:
BA XR6
Performance mods: typhoon + territory pipe with K&N filter, full exhaust, BPR generic tune, lowered, xr6t front brakes, territory rear brakes
Visual mods: 19" rim, lower grill mesh, oil pressure and vacuum gauges, engine bay lighting, foot well lights
some of my main mods
Posted: Wed Apr 20, 2011 12:08 pm
Gallery: 22 images
Ride: 2013 Ford Focus ST
Power: 175 rwkw
anyone used that seafoam stuff on the falcon's?
I hate arriving at my destination as then I have to get out of my car!
New Build Thread
the-garage-f53/the-beast-v2-0-phil-s-2013-ford-focus-st-t122703.html
Old Build Thread
the-garage-f53/phil-s-bf-sr-gt-build-thread-lots-of-pics-t98705.html
Posted: Wed Apr 20, 2011 2:22 pm
ive used subaru upper engine cleaner on my AU, and it did sweet f**k-all........ no white smoke, no change in rpm's...... nothing
falcons obviously have alot less carbon build up than subbies
Posted: Wed Apr 20, 2011 4:53 pm
Ride: Territory SX TX
I just coat the inlet in brakekleen while shes running, even cleans the goop off the spark plugs haha
Posted: Wed Apr 20, 2011 6:37 pm
Ride: 2002 AU Fairlane Sportsman
Hi 87SIlude, it may seem a stupid question but what was the reason for using this Threebond? I have been trying a few different things to try and get my XH ute to idle a bit smoother but nothing seems to work. Secondly, where is it available? Cheers.
Posted: Wed Apr 20, 2011 8:10 pm
Gallery: 25 images
I have used the motortech carby & throttle body cleaner and find it does a great job. Cheap too.
ToranaGuy
Posted: Wed Apr 20, 2011 8:33 pm
Ride: 92 EB s
Hey mate. Well decided to use it because my supervisor reccomended it to me.
At work We have several types. Seafoam, whynns diriect injection, a wurth one and tomcat carby cleaners. Id tried them all before and he told me that the threebond one wich we have been reccomended to use for subaru's as the seafoam dosnt cut it on filthy unservised subies) would sort it out easy, and it did.
As for where you buy it, I havnt seen it forsale anywhere but couldn't hurt to ask at a auto store that sells threebond products.
seafoam did a decent job on it but my throtle body was filth.
also as for the white smoke, there was both from the exhaust and then from the tyres haha. More from the exhaust tho. 18s are exy.
Take it easy all!
Posted: Thu Apr 21, 2011 9:02 am
maybe the subies carbon up because of the way the motor is laid out
Posted: Thu Apr 21, 2011 9:55 am
Power: 148 rwkw
Yep, the subs are prone to intakes gooping up because of the design. That's why they sell a Sub branded upper engine cleaner. The local Ford dealership buys it by the case to use on Falcons, so some of them must need it. I have used it on the EF, but didn't notice any difference in the way it runs. Will give the Threebond a try though.
Posted: Mon May 02, 2011 9:14 pm
Ride: 2002 AUII Fairlane Sportsman V8
What is the best procedure for using this stuff?
Posted: Mon May 02, 2011 9:24 pm
Power: 148 rwkw
Tried the Threebond on the AU, following the directions on the can, and gave it a good thrash immediately afterward, but didn't notice any difference in operation. The throttle body is visibly cleaner though. Bought the AU in September and don't know how the previous owner treated it. Have run STP Injector Cleaner through it a couple times since, and always use 98 octane (with more detergents). So maybe there wasn't much to clean.
Posted: Tue May 03, 2011 8:16 am
Ride: 92 EB s
Yea don't usually see many aus with intake problems *(becides the gasket)
My TB was filthy so had to clean something.
Did you get any white smoke?
Posted: Tue May 03, 2011 8:19 am
Power: 148 rwkw
No white smoke that I could see, which surprised me. Maybe that's a good sign.
Posted: Tue May 03, 2011 1:18 pm
Ride: 92 EB s
Would think so. What process did you use?
It is currently Thu Jul 10, 2025 6:02 pm All times are UTC + 11 hours
