SVG9 |
Hi all, would anyone know what gains there would be in running a stock XR6T motor in a N/A XR ( BF ute ) heard from a couple of people is that's what they do when the turbo s**t itself they just take it and run with a normal manifold etc, guess it would be a ecu swap as well.
XR6T has lower compression ?, would have the stronger internals - good ? & N/A xr6 stock 190kw so a X6T motor WITHOUT the turbo would be ....KW ? better gains or run like a dog ? Reason is plenty of low K's XR6T motors here in NZ but 99% have the turbos & manifolds flogged of them. Then if the turbo bits did appear wouldn't much drama to hook up. cheers. |
TROYMAN |
the turbo engine minus the turbo will have less power and torque compared to its higher com non turbo brother,,
Users browsing this forum: FGXR and 47 guests |
