ef fuel problem
Page 1 of 1 [ 8 posts ]
 Post subject: ef fuel problem
Posted: Wed Sep 11, 2013 12:03 pm
my ef dual fuel wont start on fuel :/ it has fuel coming to the fuel rail, new injectors, new fuel pump relay, ive checked the fuel pump and that works, really need to get it going any ideas??
EFII Project Progress.
2.5" Catback, POD Filter, blue neon interior and footwell LED's, smoked tail lights,scoop over snorkel , custom boot install with 15"&12" SUBS 4CH AMP, HID Xenon lowbeam kit, fusion headunit 4" 6"/tweeters 6x9's, 2 stage shift kit
 Post subject: Re: ef fuel problem
Posted: Wed Sep 11, 2013 6:19 pm
Ride: 96 EL XR6
Does it start on lpg? If so can you switch it to fuel and see if it continues running? Is fuel actually getting into the cylinders? Take all your spark plug leads off, wind the engine over as per normal a few times, (not an excessive amount, youll flood it) then take a spark plug out and if you get an instant smell of fuel after you put your nose down there a little then you know theres fuel getting in there, if thats the case then itll almost have to be a smark issue? Anyone correct me if im wrong, just trying to help a fellow out. Cheers
EL XR6, T5 Speed - Full Factory Fitted Tickford Body Kit, AU Engine, Billet Camtech 845 Cam, J3 Chip, MLS Gasket, Intake, Extractors, High flow cat, 2 1/2in exhaust, K&N Air Filter, 3.45 LSD, - My Pride and Joy
Posted: Wed Sep 11, 2013 6:20 pm
Ride: 96 EL XR6
Posted: Wed Sep 11, 2013 6:47 pm
Ride: 96 EL XR6
Phones playing up and posting twice :/ sorry
Posted: Wed Sep 11, 2013 7:59 pm
ended up getting it to work, now its blowing out white smoke from the exhaust, could it just be built up oil since hasnt ran on petrol for awhile?
Posted: Wed Sep 11, 2013 8:28 pm
Ride: 96 EL XR6
I was lead to believe oil burning creates blue smoke, white smoke could just be condensation, does it go away after the car warms up?
Posted: Wed Sep 11, 2013 8:33 pm
it did when i took it to the mechanics to get him to look at the converter.. then when i got home it started again but havnt really driven it to get warm yet
Posted: Sun Sep 22, 2013 11:04 pm
Gallery: 58 images
Ride: 2009 ve ss manual L98
Hi I'd be keeping an eye on that 'white smoke' which is actually condensation . Excessive condensation all the time can only mean one thing.......... Head gasket :/
Users browsing this forum: Google Adsense [Bot] and 58 guests
It is currently Tue Jul 08, 2025 6:52 pm All times are UTC + 11 hours
