FPV_GTp |
hi
question what transmission to use behind my EA falcon sedan Turbo charged AU 6 cylinder powered vehicle ????? ford type - auto's C4,C9,C10 C6 FMX BTR 4 SPEED 72,93,97 GM(S) - trimatic,T350,T400,powerglide,T700 Chrysler - torqueflite my choice is Ford C10 ![]() ![]() 1 . heaps of them around 2 . cheap 3 . parts readly avalaible 4 . dont need electronics to control them 5. will handle 500 to 600 Bhp will be interesting to see how the C10 handles large amounts of turbo power at the race track and on the streets abuse once again have to make a adaptor to suit behind a AU 6 cylinder to Ford C10 transmssion keep you posted and have some pictures also soon cya
_________________ WANTED - Complete BTr4 and zf 6hp26 automatic transmission 6 cylinder and V8 transmission(s) suit rebuild? Drop me a PM if you can help would be greatly appreciated - thanks |
yobboford |
personally i like the c4's, they can handle the power no probs and are relatively cheap to rebuild.
_________________ Thanks to Crescent Motors, Liverpool. |
hornet |
I'd go a 6 speed manual
_________________ 5 Speed EL Futura
EBXR8380 |
We went through this with another turbo six..Believe it or not the cheapest and strongest is the t350 with b/housing from Castlemain Rod shop...The two or three people we talked to said it costs to mod a C4 to handle that power level $4k ..With t350 approx $2k...It has better 1 st ratio compared to t400...
TickfordGhia |
the c6 will be to big u wont fit it in the trans tunnel no use going a c4 cause the c10 is just a beefed up version of that. and although i dont like to admit it the gm boxes are capable of handling more power and are cheaper to mod. and the tourqueflites are pretty strong as are all thing mopar. just depends how much power going through it. a powerglide would be pretty cool though. just the 1 gear change down the strip. but i reako the c10 is the way to go so u keep it ford and tehy can still handle a bucket load of power
_________________ ~Such Is Life....
FPV_GTp |
LOL
{USERNAME} wrote: the c6 will be to big u wont fit it in the trans tunnel no use going a c4 cause the c10 is just a beefed up version of that. and although i dont like to admit it the gm boxes are capable of handling more power and are cheaper to mod. and the tourqueflites are pretty strong as are all thing mopar. just depends how much power going through it. a powerglide would be pretty cool though. just the 1 gear change down the strip. but i reako the c10 is the way to go so u keep it ford and tehy can still handle a bucket load of power
hi my thoughts exactly ![]() ![]() cya
FPV_GTp |
LOL
hi guys fallen behind on work on my new project ![]() "will be interesting to see how the C10 handles large amounts of turbo power at the race track and on the streets abuse once again have to make a adaptor to suit behind a AU 6 cylinder to Ford C10 transmssion keep you posted and have some pictures also soon " pulled apart a V8 cleveland C10 auto that i had lying around at work and decided cause of the huge bellhousing offsets between the BTR and the C10 will do a cut and shut job nothing a bit of TIG welding does fix. Worked out how to make the tooling to hold the bellhousings in alignment and tommorrow i will spin up and mill some special tools for the job, once im finished will post some pictures Will also make some tooling to mate powerglides and turbo350 and turbo400 transmissions also so if anyone has a special need let me know can make anything work for the right dollars ![]() ![]() stay tuned
Users browsing this forum: Google Adsense [Bot] and 38 guests |
