99 au thermo fan 1
 Post subject: 99 au thermo fan 1
Posted: Tue Jan 28, 2014 8:31 am
Ride: 2000 Au wagon
99 au , fan one not getting power to the relay, if i bridge the out put terminal on the relay from the battery it works , where does the signal for it to turn on come from?
 Post subject: Re: 99 au thermo fan 1
Posted: Tue Jan 28, 2014 6:54 pm
Ride: BF II Gas Ute
Hi,
There is a good write up in the Tech. Docs. I think the AU was much the same as my EL, with 2 fans and 3 relays. There are 2 control signals from the ECU, fans on and then another for high. In the low setting, the Fans are in series, and high they are in parallel. Sometimes the ECU needs to be reset, as it wont run them on high. Hope this helps.
Regards 96ELGli
Posted: Tue Jan 28, 2014 7:54 pm
Gallery: 20 images
Ride: ED Falcon
Power: 133 rwkw
One of the contact pins on fan 1 relay should have power and one of the coil wires should have power with the key on... The computer grounds the other side of the coil wire to engage the relay when the car is getting hot... That relay must also come on for high speed otherwise only one fan will work on high speed...
My AU the high speed only engages on a really hot day when the AC system builds too much pressure... It runs on low speed most days when stopped idling... And probably doesn't run at all when driving...
Cheers,
Tim
Users browsing this forum: No registered users and 77 guests
It is currently Fri Jul 11, 2025 5:04 pm All times are UTC + 11 hours
