EF/EL 4.0 Engine number location.
Page 1 of 1 [ 9 posts ]
 Post subject: EF/EL 4.0 Engine number location.
Posted: Mon Nov 24, 2014 6:23 pm
Ride: Falcon XR6
Hi All,
A while ago I purchased another EF XR6 on which the rego had lapsed.
I rang VicRoads today to make a booking for a registration inspection and was asked for an engine number as well as the VIN number.
I had thought that the engine number was part of the VIN number and said that to the VicRoads person that I was talking to ... who replyed that the engine number was different.
Not knowing any better I replied that I would call again once I had the engine number.
So off I went to have a closer look at the vehicle ID tags to see if they listed the engine number ... which they did not.
So I grabbed a torch and had a look around the block on the exhaust side looking for anything that resembled an engine number ... I couldn't find anything that stood out as an engine number ... the only thing I found was a 4 digit alphanumeric code cast into the block near the bell housing.
Tried a google search and came up with conflicting opinions of where people thought the engine number is located so that really didn't help.
I then had a look on my current XR6's engine block and found that the 4 digit alphanumeric code was indeed different to the other XR.
To further add to my confusion I dug out an old registration label for my current XR and it confirmed my earlier thought as the engine number listed on the rego sticker was part of the VIN number.
So if the engine number is part of the VIN number is it stamped anywhere on the block?
Does anyone know exactly where to look for this elusive number?
Any help would be appreciated.
Cheers,
Alan.
95 EF XR6 Manual
Pioneer, Oz Audio, Butler, Image Dynamics, Audison
MEASQ - Aust Champion Intermediate Class 2006
MEASQ - Vic Champion Intermediate Class 2007
MEASQ - Aust Champion Intermediate Class 2007
MEASQ - Aust Champion Expert Class 2008
MEASQ - Aust Champion Advanced Class 2011 (Shared)
 Post subject: Re: EF/EL 4.0 Engine number location.
Posted: Mon Nov 24, 2014 7:51 pm
Gallery: 16 images
Ride: ford ef2 xr6
Engine number will only be part of vin number if car still has original factory fitted engine.Ef six cylinder engine number is located at rear of engine block on exhaust side(Note:According to the factory workshop manual I have here,early build vehicles have engine number stamped on front of cylinder block on exhaust side.).
Posted: Mon Nov 24, 2014 8:51 pm
Ride: Falcon XR6
Thanks for the replies guys ...
I revisited my workshop manual and found the locations that you both referred to ... don't know how I missed it when flicking through it earlier today.
Will look at below cylinder 1 exhaust port tomorrow.
Thanks for your help.
95 EF XR6 Manual
Posted: Mon Nov 24, 2014 8:56 pm
Ride: 93 ED sedan
Power: 161 rwkw
The engine numbers on EA to ED were stamped near the P/S pump....EF & EL & AU (some EL & AU were dot matrix) stamped on the same side near the bellhousing.
http://youtu.be/jJTh9F3Vgg0
Posted: Mon Nov 24, 2014 9:21 pm
Ride: ef falcon futura
Power: 154 rwkw
Some ef blocks had it near the p/s pump. I have one sitting in the shed im pretty sure. Im guessing early ef
ef futura, pacemakers, 2.5inch catback, k&n panel filter and 3.45 lsd. extractors/cat, ticky head, custom cam grind, t5. now onto cosmetics.
Posted: Tue Nov 25, 2014 7:39 pm
Ride: Falcon XR6
So I had a look at both my XR's today and found the engine number on both.
On my red XR which is an EF 1 the engine number was stamped under the exhaust port of number one cylinder ...
And on my green XR which is an EF 2 (the one I'm getting registered) the engine number was stamped on the back of the block flange where it meets the bell housing again on the exhaust side.
Both cars still have their original engines.
So EF 1 is at the front of the block and EF 2 is at the rear.
95 EF XR6 Manual
Posted: Wed Nov 26, 2014 6:16 am
Ride: 96 EL XR6
What build month is your EF1? It would have gotten one of the last ED blocks, as stated earlier - SOME early EFs had the engine number located near the P/S pump.
No difference between ED and EF block anyway, same same,
EL XR6, T5 Speed - Full Factory Fitted Tickford Body Kit, AU Engine, Billet Camtech 845 Cam, J3 Chip, MLS Gasket, Intake, Extractors, High flow cat, 2 1/2in exhaust, K&N Air Filter, 3.45 LSD, - My Pride and Joy
Posted: Wed Nov 26, 2014 8:31 am
Ride: AU XR8
actually its the other way around, late ed had ef block and head..
Posted: Wed Nov 26, 2014 11:53 am
Ride: Falcon XR6
My EF I is a January 95 build ... and my EF II is a December 95 build
That makes sense ... similar scenario as EL hybrid leading into AU
95 EF XR6 Manual
Users browsing this forum: Google [Bot] and 91 guests
cron
It is currently Thu May 22, 2025 5:59 am All times are UTC + 11 hours
