Weird CRT LP fuse issue...or is it?
Page 1 of 1 [ 7 posts ]
 Post subject: Weird CRT LP fuse issue...or is it?
Posted: Fri Jan 09, 2015 11:42 pm
Ride: el wagon
Gday guys,newbie here
Ive recently got an EL Wags off my parents.Cars not bad for 18 years old
So...theres been 1 or 2 times it has troubles firing.It cranks fine but wont turn over.
I had NRMA come out,jump the battery after getting a little over zealous trying to make it fire.As soon as he jumped it,it sprung into life
After further investigation,i red on here about the CRT LP fuse.The fuse is fine,not blown but obviously if i take it out,it has the same symptoms as when i had to call the bloody mechanics.The car doesnt run an interior light globe either.My question is,would it just be a simple fuse issue with the car not starting every now and then and and after the car gets jumped,or should i investigate further?
#elcooncruiser
 Post subject: Re: Weird CRT LP fuse issue...or is it?
Posted: Fri Jan 09, 2015 11:50 pm
Ride: ef falcon futura
Power: 154 rwkw
Next time it happens give the dash near your left knee (beside the steering column) a whack while cranking. Sounds like a bcm issue
ef futura, pacemakers, 2.5inch catback, k&n panel filter and 3.45 lsd. extractors/cat, ticky head, custom cam grind, t5. now onto cosmetics.
Posted: Sat Jan 10, 2015 12:10 am
Ride: el wagon
Doesnt the BCM control the fuel pump?
I can hear it whining when i throw the reds on even when i had the starting issue
#elcooncruiser
Posted: Sat Jan 10, 2015 12:14 am
BCM controls a few items .... not just fuel pump
Posted: Sat Jan 10, 2015 12:34 am
Power: 154 rwkw
Ecu controls the pump im fairly sure. Bcm controls all your body electrics and smartlock. Alot of e series you need to thump the dash. It can be a bcm issue or wiring into the bcm
Posted: Sat Jan 10, 2015 10:47 am
Ride: AU XR8
the ecu triggers the fuel pump relay..
if the engine cranks over its generally not bem related..
Posted: Sat Jan 10, 2015 11:01 am
Power: 154 rwkw
My old ef used to crank but not fire until i whacked the bcm
It is currently Sat May 17, 2025 4:32 pm All times are UTC + 11 hours
