car10001 |
hi
looking to fit a new throttle body and wondered the following how would you get a au one to fit on a ef manifold what parts do you need to run the au throttle body on a ef manifold. 2. what other throttle bodys from the usa fit a ef manifold and what parts are needed to make it fit. 3. will a v8 throttle body fit a 6 cyl wether au xr8 or a ef/el v8. 4. whats size of ef/el, au1, au2 throttle body bore any information would be good |
SWC |
{USERNAME} wrote: hi
looking to fit a new throttle body and wondered the following Q) Why? 1. how would you get a au one to fit on a ef manifold what parts do you need to run the au throttle body on a ef manifold. A) TPS is different plug etc. 2. what other throttle bodys from the usa fit a ef manifold and what parts are needed to make it fit. A) No need, the stock Throttle Body will handle more than enough power. 3. will a v8 throttle body fit a 6 cyl wether au xr8 or a ef/el v8. A) No 4. whats size of ef/el, au1, au2 throttle body bore A) All 64mm any information would be good |
car10001 |
that ok thanks will probably just look for a really good standard one, plus how much better are the 68mm ones over the 64mm ones the performance people say they make a difference
SWC |
Yep they do, at wide open throttle. Great if you drive around at 5500rpm all day.
bry40l |
{USERNAME} wrote: Yep they do, at wide open throttle. Great if you drive around at 5500rpm all day. yep bad for torque good for high reving hp,
_________________ BF XR6 |
ahmedkayihan |
Age: 34 Posts: 123 Joined: 21st Mar 2011 Ride: four wheels and an engine Location: right over there... |
aaah, so its all torque and no action...?
(ok bad joke) lol |
naughtyfalcon |
au throttle body is a straight fit on ef , you will need to cut the isc plug and use spade terminals to connect the au one , you will need the air intake from the filter to the throttle body and the pvc breather tube from the au as it goes on the side of the air intake tube not in the throttle body like the ef, it will work fine and you may notice a little better take off .
Users browsing this forum: No registered users and 63 guests |
